and the second is that now that the build is finished i've got nothing to work on![]()
The Splash is a lot better for a show-off build with a custom loop, that's for sure. I'm slightly jealous of it for that, but that was one of the sacrifices to keep the size of the M1 down. Anyway, I think they appeal to somewhat different crowds; not everyone wants a window on their case.Both cases are shining examples of innovation in water-cooling-friendly small form factor. I'm lucky I need two cases, Splash for folding, M1 for the living room. Perfect![]()
Looks like a pretty standard EK block, so it should be fine. Fans are really a tiny part of the overall power consumption picture (~1-3w each, compared to 200-300w for just the GPU). Besides, you still need fans on the radiator, plus the pump.Would a VisionTek CryoVenom R9 290 fit....consume less power with no fans?
I put together a little pictorial guide for the screws and other parts of the M1, just in case there's anyone who still needs itShould've done it a while ago, but better late than never.
This is my plan. I do not intend on using a filter on the motherboard side as I have positive air pressure. There may be a very slight amount of dust getting in over a long period time due to the pull of air from the PSU but that should just stick to the PSU filter.Maybe on the left panel with the fan bracket removed
I was hoping for that as well, but Necere said there would be fitment issues going for a 1-piece on the inside panels..
If you do try this, please let us know how it works out (and possibly if it fits with the fan rack installed, or if it fits on the opposite side behind the mobo). Also thanks for the 80mm round filter info, appreciate that!
Finally finished the last part of my build today so thought i'd share my thoughts and build with you.
I put together a little pictorial guide for the screws and other parts of the M1, just in case there's anyone who still needs it![]()
Thanks! Compiled them into a PDF if anyone else's M1 folder of info is getting cluttered like mine
Feel free to upload it to ncases.com or post to the front page if needed..
http://www.sendspace.com/file/bapxdz
After finding Prglin's pics of an ATX PSU install in the NCase (posted back in Nov), I discovered that an ATX doesn't orient along the right side of the M1 like an SFX PSU but along the front side with the fan blowing towards the back. So now I find that I have the exact problem that I didn't think I had - "PSU socket orientation should be as on left if close to PSU edge, otherwise the angle plug may have fitment issues".
I'd like to use this ATX PSU, so am looking to snipping off the plug of the supplied NCase cable to the PSU and install one that is an 90 angle or is rotated 180. Or replcing the cable if one is to be found somewhere. Can anyone offer a solution? Perhaps I'm not looking using the correct terminology.
Thank you!!
Another hour research. To replace the entire NCase cable, possibly an IEC320 C13 left-angled power cord with bare leads (ROJ - remove outer jacket with slug) would work, depending on whether it is fairly easy to remove, mod and /or replace the power socket on outside of NCase to connect bare leads to.
Aibohphobia, it's a Seasonic SS-660XP2. Thanks for the info on what the other end is called. I'll look at that as an option, although I have seen a DIY 90 Degree Right Angled Power Supply IEC Plug / Connector / Adaptor Vertical that I think would work. Snip the end of the cable, open this connector and screw in the wires.What PSU are you trying to use?
The other end of the cord would be a IEC320-C14 Male Panel Mount. It probably would be better to get a new one rather than cutting up the one that comes with the case.
That said you have to make sure that the plug is low-profile enough to clear the top panel ,the stock one is very slim.
That build is a work of art and inspiration for my future builds. Nicely done! What cables are those? Thanks!
Yes, I got it and very happy with it. It's quite amazing how Necere has come up with a winner with so little actual testing. So much respect
I had planned for a quick build, but now I realise this case deserves some proper attention.
If your package is on the Tsingtao Express then the dates are Dec 16th - Jan 17th Kaosiung to Antwerp, Jan 21st - Jan 22nd Antwerp to Amsterdam via inland waterway (barge). Transit time 37 days.
Adamantium,
Which side should be the intake on this picture? The "bigger" left side or the right side with the smaller portion of the reservoir with FrozenQ on it?
At least when I was bolting mine on (obviously nowhere near as far along as yours, and only mounted in isolation), I had a bit of wiggle room as to how high or how low the res would sit on its bolts. I set it as low as possible, and it seems like my barbs would be far more centered than yours. I'd wonder if that's just a manufacturing irregularity, or if you loosen the mount, if you might get it to sit a bit lower?
I see that since this, you've gotten it sorted, but the fittings still look a bit high relative to mine. I'm still curious if yours has any of the play that mine does, or it you couldn't put it lower due to other issues.
So it sounds like you were on the Tsingtao Express. Glad for all who were delayed.
Thanks Gandergray for the info. I saw the stayonline variations and have looked at the Shurter options you've mentioned.FYI: Because I installed a more power hungry video card in my build, I also chose to install a 140mm power supply (SeaSonic S12G-750 http://www.seasonicusa.com/S12G.htm ). The AC inlet orientation of the SeaSonic S12G-750 precludes use of the internal right angle connector 18/3 AWG power cord that is provided with the M1 NCaseand I wanted to use the more robust 16/3 AWG power cord that came with the SeaSonic S12G-750. You can purchase more robust power cords with IEC 320 C13 left or down angle connectors from retailers, such as: http://www.stayonline.com/5-15-c13-angled-cords.aspx , but the molded IEC 320 C13 connecters typically have a height of 39mm, and thus, are too tall to fit in the available space between 140mm power supplies and the top of the M1 NCaseeven when plugged into the power supply. To solve the height interference problem, I chose to use a rewireable IEC C13 connector, namely the Schurter 4012 http://www.schurter.com/Components/Connectors/Cord-Connectors-rewireable/4012 ; or 4300-6 http://www.schurter.com/en/Components/Connectors/Cord-Connectors-rewireable/4300-06 . I cut off the molded IEC 320 C13 connecter, rewired the 16/3 AWG power cord to the Schurter connector, and then, instead of attaching the cover or lid of the Schurter connector, I wound electrical tape over the exposed wires and screw terminals. By refraining from using the cover or lid of the Schurter connector, there is plenty of clearance or room between the M1 NCase cover and the top of the Schurter C13 connecter.
I think it was the China Express because tracking said the case showed up in customs on 17th.
These are the parts I'm getting for my brother:
- Asrock Z87E-ITX mobo (bought already)
- i7 4770K or S (haven't decided yet)
- Noctua NH-C12P SE14
- 8GB Mushkin Redline CAS 7 DDR3 1600 RAM
- Adata S511 120GB SSD
- Silverstone ST45SF-G w/PP05-E cable kit
- AMD or nVidia video card - ?
Will I have any problems with height or size restrictions with these components? As for the video card, my brother says he couldn't afford it unless I pay for it so I'm deciding on the i7 4770K or S.
There's also the spreadsheet, which has information on parts compatibility.You didn't identify what type of cooling system you are planning. If you are planning to use the stock Intel cooler there should be no problem. Otherwise you need that information to know if there will be a problem. If you are planning to go with the stock cooler then I wouldn't by the K since you probably aren't planning to overclock. I take it back you did specify. I think there are posts about the cooler you have chosen in this thread that you can look at. I think the 140mm has problems fitting.
The ones on the bottom do. The ones for the side go directly on the fan bracket, which is inside the case.So the Demciflex filters go on the outside of the enclosure, correct?
See here.How do they look?
Looks are subjective. More importantly, separate filters work better, since you can adjust them independently as needed to better clear the screws.Wouldn't a single 2x120mm filter look better than 2 filters?
They actually fit.How are the custom Demciflex filters any better than the standard off the shelf versions?
