Thank you. I guess I'll just throw a cover over the top when not in use. Seems easy for dust to get inside through the top otherwise.
ST45SF-G V1.0 did not have caps on the stock cables. V1.1 and V2.0 do have caps to smooth ripple. These are added in subsequent versions to improve performance without having to redesign new circuitry inside the PSU.
Maybe I'm just confused, but you mean like the crappy diagram I drew or like, the tubing loops the same direction? Like both go clockwise, rather than the top clockwise vs bottom counterclockwise in my picture?
How is everybody else running their H220 pump?
It seems like it only runs when running at full RPM. At least on my motherboard, when using the headers, I have to run it at full RPM. Otherwise, the pump will stop and start. I guess the Z87I-Deluxe adjusts the RPM through voltage.
I have the pump connected to one of the chassis fan headers and my rad fans connected to the CPU fan header.
Reason why I ask is that at full tilt the pump is a little loud.
Edit: Just received a response from Swiftech saying that if I connect the PWM splitter that comes with the H220 to the power supply and then use the header connection from the splitter to the motherboard that will adjust the RPM of the pump and not adjust the voltage. I'll be giving that a try to see how that goes and report back.
Hey everyone, I built my rig a few weeks ago (M6I, 4770k cooled with H220, GTX TITAN on stock air) and I've been noticing that my hard drive (directly under the TITAN) has been getting incredibly hot, too hot to touch. This is pretty bad for the hard drive's longevity, right? Is there anything I can do to cool it down? I'm assuming this has to do with it being right next to the video card but I expected that the enclosure of the video card would keep heat along the path of the air, from the intake to the exhaust out back. I don't want to destroy my hard drive.
@wake: hmm... what about this?
Just an FYI, my v2.0 does not have a cap on the ATX cable. So they may have redone the PCB.
To those who have a 3.5" HDD on the bottom of the case: What temps are you getting on your hard drive? When my GPU gets hot the HDD almost hits 55C. I think Necere posted a link about Google's study on hard drive reliability in regards to temps, but I just want to make sure 55C isn't too bad for my hard drive's longevity.
According to this study (dunno if this is the one you were referring to), though they only study up to 50C, their conclusion is that there is no massive increase in HDD failure due to temperature.
@rajeeves
Maybe, get one of those $10-$15 (USD) HDD cooler assy's that bolt to the bottom of the HDD?
I have about 10 HDD's "out in the field", last I heard they're still running & cool to the touch. Make sure the fans have clearance to draw in air to circulate on the bottom of the drive. Even the internal system-warmed air is better. You are correct that the HDD as you described is being destroyed.
I also put voltage reducers on them because they're so noisy and function quite well at much lower rpm's. Even the body of the fan assy. acts as a direct-contact heat-sink. It can cause HDD mounting problems that I never found insurmountable, just bothersome. But the HDD's live!
Is everyone shortening their tubes on the H220? I'm not directly opposed to doing it, but if leaving it stock length how are people orientating the rad and looping the tubing? I've looked at pictures and couldn't find a stock H220 or a good picture that shows how its laid out.
Anyone using the Asus ROG mini-itx have problems their i/o panel shield not being a tick to high? I can still plug in a lan cable and a usb cables, just worried that the usb cables may touch the i/o shield.
@OverRated and others
Hi,
When a regular poster flamed me [ref: my posts #10047 (Jan 22) and #10051] at least he included a link, for which I'm grateful. Thought everyone would be interested, so I am including it below. I guess I should have checked the entire [H] site, or maybe the entire Internet, but my posts were made because of my discovery of the cap on the cable, and no knowledge of where data was available, and would have handled it myself without posting, but I thought that was the point of this forum, to try to inform others who might be in the same position.
Anyway, there's a great [H] thread at
http://hardforum.com/showthread.php?t=1707073&page=28 dedicated specifically to the ST45SF PSU! The cap is old news there. So shoot me, I guess. Lots of really good info there, including about the cap.![]()
Well, i have some very strange problems with my hardware >inside< the ncase. Everything fits well and is not overheating (checked every temperature sensor) - but i get ongoing system reboots after a uncertain anmount of time (sometimes after minutes, then hours), also when the system is completely idle. It's like someone is pulling the power plug and then put it back in. I even don't get bluescreens (the automatic reboot in windows is disabled, the event log is empty). All cables are perfectly on their places, i've checked it multiple times.
Here a short overview of my components:
CPU: i7 4770K with a Noctua C12P-SE14 Cooler
MB: Asus Maximus VI Impact
GPU: (Gigabyte) NVIDIA 780Ti (Reference)
RAM: 2x G.Skill 1600MHz 8GB DDR3
PSU: Silverstone ST45SF-G 450W
HDD: Seagate ST4000DX001 4TB
SSD: Samsung 840 Pro 256GB
OS: Windows 8.1
I thought the issue might be the psu, but the surprising thing is, if i take the complete hardware out and install it on a benchtable - everything is working without any problems.
I will further investigate this, but i can't figure it out yet. Maybe anyone here have an idea what the problem might be?
But the amount of people as a hole ....
They flamed you because you created a huge excited post that read like you thought t... You didn't need to scour the forum or the internet. Only look at the thread that's almost always within a few threads of this one that clearly states the name of that PSU. ... ...
Only a very small portion of the group in this thread ... ... ... ....
The cases in The Netherlands finally get delivered!
I can pick up the case tomorrow, got a receipt in my mailbox to pay 26,65 euro at a postoffice of choice.
For who wants yo know: delivered by postnl (yeey!)
So every think in and im leak testing but there a load of bubbles in the loop and i can hear the pump cutting them up.
@finas: if you're still around here, I notice on your dropbox link to IMG_6899.JPG, the side mounted 15 blade fan (Scythe SY1212SL 12H-P). Is that for your H80i radiator? (Remember, I haven't opened the box my H80i is in). Don't the sharp bends in your cooling lines restrict coolant flow and increase wear on the pump? Does the setup allow you less restricted access to the mobo and internals than a big fin assembly?
I specified the filter without the magnetic adhesive backing, since the PSU housing is steel and it doesn't need it.2 quick questions for Necere, Dstart & PLHHSB..
The DEMCiflex ST45SF PSU filter, as applied to an ST45SF-G.. due to the fan being partially covered by the chassis, does the adhesive strip and filter need to be applied to the PSU *before* installing it into the case?
That's an EK Coolstream PE rad, yeah? That's why. It's 130mm wide, which is 5 to 10mm wider than most 120mm rads. It's a very tight case - not everything is going to work with everything. Measure everything twice, but sometimes it's still just going to take trial and error.
Let's see how long it takes for it to arrive to me in the Netherlands..
Who's willing to bet that it'll take me at least another month?
My luck is so horrible that i'm waiting for it to have been squashed by a truck.
Has yours not even reached customs yet?![]()
