Do you think there would be any space for 45mm radiator with an apogee Drive II?
Yes we had this decision around 5-6 pages back you should be able to find it.
1850's. Totally silent when running anything under 12v. Even at full blast, it just has a bit of a "windy" sound vs the stock helix fans. Definitely much quieter, without a doubt.
The build is what I'd consider totally silent. Just the slightest little "tick" from the H220 pump. The psu fan is modded too
does m1 come with fan filters? Haven't really look at mine just took it out and put it back in
yep, 4 screw in
This article will discuss seldom known facts about fan filters used in computers and how you can use this knowledge to maintain consistently high cooling performance for your PC.
Nylon is a material that was commonly used during the Second World War where it was used to make tires, tents, ropes, parachutes…etc. Since 2007 SilverStone has been using nylon as the material of choice for its filters, cases such as the Sugo SG03 had a filter constructed with plastic frame and nylon net. Compare to the traditional cotton and plastic fan filters which are commonly used on low-end computer chassis’s, nylon filter offers less air resistance which is more suitable for fans that offer direct airflow.
Although nylon fan filters are more expensive and complicated to manufacture, we at SilverStone, insist on producing fan filters with nylon to provide the best balance of cooling and dust reduction performance. This choice reflects highly of our philosophy in creating the best possible user experience for our customers.
A:Cotton filter B: Plastic filter C: Nylon filter
Although they both appear to allow air to pass, a closer inspection using an enlarged photo clearly reveals that the proportion of open holes on the plastic filter are far smaller compared to the nylon filter.
Filter type and airflow rate
Remaining airflow
Cotton Filter 20%
Plastic Filter 41%
Nylon Filter 65%
The results in the above table were obtained by testing a SilverStone FN121 fan with different type of filters to determine their remaining airflow rate.
From the above table you can clearly see that both cotton and plastic fan filters offer more airflow resistance. If you are using either of these types of filters, we recommend you to purchase SilverStone’s Air Penetrator fans, which are designed to maintain good air pressure even when used with highly resistant air filters.
Maintenance:
To ensure optimal cooling performance, fan filters need to be cleaned regularly. So to make this process easier, we have constantly improved fan filter systems in our chassis over the years.
Method of Cleaning:
Cleaning with a brush
Fan filter can be cleaned using a soft brush. Please DO NOT use a steel brush as it will cause damage to the filter. We recommend you to wear a respirator when cleaning the fan filter to prevent inhaling unnecessary dust.
Cleaning using a vacuum cleaner
If it is difficult to remove the fan filter, cleaning with a vacuum cleaner is the best method. To prevent the vacuum cleaner from damaging the fan blades of the fan, please secure them before cleaning.
Cleaning with water
Washing the fan filter is the best way to clean the fan filter. After washing the fan filter with water, dry the filter at a well ventilated area out of direct sunlight.
DO NOT use a blow dryer, oven or microwave oven...etc to dry the fan filter. This will damage the fan filter.
If you feel the drying process is too time-consuming, we recommend you to keep a spare set of fan filter as backups. DO NOT reinstall the fan filter before it is fully dry, it may cause shortage or damage to other computer components.
Important notice:
Purchasing the fan filter
To purchase a retail fan filter as an upgrade or replacement in the event of loss, damage or simply as a backup, you can search on our website for the nearest distributor: http://www.silverstonetek.com/wheretobuy_all.php?area=en
Fan filter will expand when wet
The fan filter net is made of nylon which will expand in high humidity environment or after coming into contact with water. This is a normal phenomenon that will make the filter net look uneven or wrinkled. Once you allow the nylon filter to dry completely, it will contract and resume its
Finally finalized my final build list! Took a while, but it's looks good.
I'll be purchasing the parts within the next 2 months.
How's it looking? Any concerns?
http://pcpartpicker.com/user/Commander_/saved/3a9g
I'm little bit late to the boat on this. I've only just heard of this chassis, but after doing a fair bit of reading it won me over. Is there any way to still get this case? I NEED it!
and still no frozenq res nor email replies....
adamantium you get yours res yet ?
Any reason for going with the U9B over the C14? Just to save some money?
Also, I see that your getting the PP05-E cables. You can save $5 if you get them from Amazon. I know Amazon says their out of stock but I ordered mine from them and they shipped it 4 days after I purchased it. I think another person in this thread had the same experience.
why the 92mm fans? bigger fans push more air and is quieter
Why do you need pp05?
Also the PP05-E cables will make my life easier when cable managing.
Please note: I don't care if it sounds like a jet in a box! My headphones are on 24/7
1 x 24 / 20-Pin motherboard connector(300mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(400mm)
1 x 8/6-Pin PCIE connector(400mm)
1 x 6-Pin PCIE connector(400mm / 150mm)
3 x SATA connector(300mm / 200mm / 100mm)
2 x 4-Pin Peripheral connector (300mm / 200mm)
1 x 4-Pin Floppy connector(300mm / 200mm / 200mm)
1 x 20+4pin ATX connector (350mm)
1 x EPS/ATX12V 8pin(4+4) connector (350mm)
2 x PCI-E 8pin(6+2) connector (350mm)
2x PCI-E 8pin(6+2)+PCIE 6Pin Connector (350+50mm)
1 x two (2) SATA 90˚connectors (350+50mm)
1 x two (2) SATA 180˚connectors (300+150mm)
1 x two (2) 4pin +1 x Slimline SATA connectors (300+100+100mm)
1 x two (2) 4pin + floppy connectors (350+100+100mm)
1 x three (3) SATA 180˚ +1 x Slimline SATA connectors (300+150+150+150mm)
1 x 20+4pin ATX adapter (350mm)
4 x PCI-E 8pin(6+2) connector (350mm)
1 x two (2) 4pin connectors (300+100mm)
eBay or the For Sale section is your only option for now.
I guess its better than 90 dollar cables from moddiy
Alex sent me one of the original prototypes, but I haven't ordered a finalized one yet. I have seen two people post that they have received theirs so far. I don't know if that is all that have been shipped or just all who care to post. I have sent a message to Alex asking for status. I will relay anything I receive.
Case #0051 arrived in UT on Friday. Post man didn't even try to deliver it. I had to wait until the next day to pick it up. The case is amazing! I have had thoughts of selling, but after seeing it, I couldn't part with it for anywhere near a fair price!
Computer is built with what I have so far:
Gigabyte z87 wifi mobo
Core i7 4770k
Stock cooler (cooler master glacier 240 coming soon!)
Crucial 16GB vlp 1600
Nvidia GTX 460 (I know, still working on a replacement)
Samsung 840 ssd for windows 8
500GB 2.5" HDD for data
80GB 3.5" HDD for OSX ( this will be replaced with ssd sometime after video card upgrade)
2x120mm no-name, non-pwm, really noisy fans (to be replaced by water cooler above)
1x80mm no-name fan on case bottom front slot.
Silverstone 450 modular SFX power supply.
The case is great to work with. This is my first SFF build but I have built multiple mATX and ATX machines. Be careful because the black paint on the inside can scratch!
Thank you Necere Wahaha et all, this case is amazing!
The black paint every where can scratch apart from the panels so even putting fans on the bottom will kill the paint washers should of been sent along with the screws for those who like there cases in mint condition.
dude, do you really have to have complain about everything?
My first build went for the u9b to respect the airflow pathways however I had a non blower gpu and it suffered under gpu load. When the gpu is not loaded, it's performance was sufficient but nothing spectacular. With sufficient fan power where noise is no concern. The u9B will be satisfactory for mild overclocking. I would strongly recommend gentle typhoon 92mm fans if you can acquire them. I got significantly more airflow and better temps over the noctua fans. The noctua fans had insufficient static pressure to be as effective as it could be.
The c14 I now have is significantly better a performer. Noise to thermal delta ratio is significantly improved, but even if noise is irrelevant, the temperatures and overclocking overhead is not something to be ignored if you have the option for the c14. This means your not needing the side panel HDD and have the budgetary allowance for it. I've ended up buying both coolers but do not regret the change.
The PCI-e cable is missing its 6 pin so its useless.
ModDiy cables are custom made, you can ask for the PCIe to have 6 pin, 8 pin, 8+6 pin or 6+2+6 pin whatever you need for your rig. Those pictures are just examples.
Here is 8+6 pin http://www.overclock.net/t/1386655/completed-c-o-m-p-a-c-t-s-p-l-a-s-h-0-0-8/20#post_19929186
I was going to use my H100i fans on my new rad instead of buying some Corsair Air Series SP120 High Performance Edition because of the stats what do you guys think ? i heard they where meant to be the same fan but looks like there better ?
Though slightly longer than the stock ST45SF-G cables; routing and hiding their new thin cables should be infinitely easier to work with, and much nicer looking to boot.
Also the PP05-E set should be easier to shorten, since you can skip the sleeving step and still get nice looking results. For $25 it's a no brainer imo.
Here's Lemkeant's build using that set, which I could definitely live with..
