We will not apply the sticker, just included with every unit
THANK YOU!
We also found a name we both agree on, stay tuned.
Oh, I guess that's good too.
BUT YES!!!! JUST A STICKER!!!
No. The plan is to do a 2-phase crowdfunding campaign; phase 1 to get a prototype made and (hopefully) get some test hardware, and phase 2 for production, where backers will receive a case.Can we pre-order?
If the sticker is die cut or kiss cut, it'll look a little less low-budget. Cutting increases the cost of the stickers only a bit.I'm going to qualify w360's statement with the following: we will include a user-applied sticker in lieu of a logo printed on the case if a significant majority of people prefer it. If we have a successful phase 1 (prototype) crowdfunding campaign, we can do a poll either before or during phase 2 (production) for the logo (and possibly color).
I was leaning toward the sticker option because many people, including myself, were not all that thrilled with the current name/logo and felt like it detracted from the design somewhat. I don't consider a sticker a great alternative though, because IMO it would look cheap and not work particularly well with the design. So really only a better option for those who want to go logo-less.
However, the name that we're going with is one which I'm much happier to have printed on the case, and I feel it's an important part of the design which helps to give it an identity. But again, if a majority are against it, a sticker is an option.
my guess is nerdgasm fap01
While that layout is similar, the psu choice and location sucks. It also looks quite a bit bigger.
A server type PSU is going to be loud!
Ok, duh, I was wondering what the silver box was... duh, server style psu.. lol
Actually, I'm pretty sure I just found the PSU they are going to use. It's supposed to be semi-fanless up to a certain load http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=276
edit: after actually reading the review, it does get loud like a typical server PSU. But is basically fanless w/ little load/temp.
Some facts about the new name:
- It isn't anything that's been shown or suggested in this thread.
- It's not actually new, and in fact predates this project. It was something I used on one of my previous concepts that I originally showed to w360.
- I suggested it for this project early on, but w360 rejected it. Not because he disliked it, but because he had a different idea for the name.
- It's a name that is meaningfully related to the design.
- It's two words, neither of which is "case."
Does anyone know of any better alternatives for sound? :/ External USB3.0 cards, miniPCIe risers or the like that would allow for gaming GPU + higher end audio card?
This. Unless you buy soundcards for [H]ARDCORE GAEMIN' then a great external DAC and a good pair of cans or monitors will do wonders.External DAC. I have the Audioengine D1, but there are plenty of options. After buying it, I wouldn't buy an internal sound card again. It has a very small footprint, I like the volume control knob, and I like having the option to plug it into other computers. It's not self-powered and therefore not truly portable, but it's perfect for my needs.
If you're really desperate for an internal card, you can probably find a place inside the case to fit a riser cable and then drill a hole in the soft aluminum to mount the card.The thought occurred to me, and if there are no good motherboard options when Haswell comes out then this will probably be the route I have to take. It will create some limitations on the eax side for gaming but that will be a necessary sacrifice I guess.
Edit: my plan was to try and fit a creative titanium hd in there
Looks like Silverstone is coming out with a case that's fairly similar to one of our earlier designs. Interesting.
It's an SG09...with a facelift...no need to go into panic mode. That and it has been posted already.
Is there any replacement for Tecnofront Nano reservoirs? As they are discontinued. Thanks in advance for replies finding similar reservoirs.
You could probably fit a micro-res in there somewhere.
