Black No. 0142 with no ODD top now living comfortably in Tyro, NC. I'll check all parts this weekend when I have proper time. Also, can someone re-link spreadsheet?
Here a link to pictures from my build (Swifttech H220, Asus Impact, EVGA Geforce 780 Hydro Copper).
You can see what I mean by video card slanted and not the cleanest cable management. I am happy anyway since everything works perfectly so I guess the PCI_E express slot and the video card can handle it. Been gaming on it for 3 days now with no issues.
http://imgur.com/a/cV1I6/all
If it is the fittings being pushed down by the rad, try this:It a risk but I think it a much smaller risk then many people would believe. They make those PCB's fairly strong. I seen sagging video cards run for years with out issue. Defiantly not something I would recommend or risk someone else money with but it a risk am willing to take with my own money in this instance.
Truthfully am more worried about the H220 pump failing then the video card failing.
I think it due to fittings/tubing. When I install the h220 radiator it pushed down on the EK CSQ G1/4 Thread 90° Fitting Adapter attached to the GPU. I pushed really hard to get the skew in to attach the radiator and notice afterward that the video card was bent like that.
Edit: Just confirmed steveo2400 was banned. What's up with that?
If I had to guess, he may not have read the rules first (see the parts regarding vendors at the bottom).Steven got banned. Don't know why or how....but that's his status.
Thanks for all the images. That helps a lot. Sounds like you got a good one. I assume the holes line up properly for the fittings on the inside? Were the thread inserts loose on yours?
Hey adamantium you get your case yet?
1. Move the AC inlet to the alternate location
2. Reinstall the fan bracket on the higher screw holes
I guess so . All the holes line up properly and with a little adjustment before you tighten the screws the ports in the back line up dead center as well. The thread inserts seemed fine. I've installed and removed the reservoir a couple times now.
That is good to hear. Thanks again for the info. Can't wait to see some running with the reservoir.
Yeah, that's something I still need to do. Once my case arrives I'll take a picture and label them. In the meantime, there's this post from a couple weeks back. It's a little cluttered because it's Phuncz's pic with my labels edited in (in red), but it should still be useful.I've been spending a few hours today putting my M1 together. Still playing with it, but I wanted to ask:
Is there a post or guide on what all the different screws are for? Some look to be for the fan filters, others I have no idea what they are. I'm sure someone has explained it in the 450+ pages but my searches have come up short.
Thanks!
Upon closer inspection I don't see any stress cracks in the acrylic and from an angle it looks beautiful. I do wish they spent a little more time cleaning the inside of the acrylic
Reservoir lines up a couple mm above the bottom of the i/o shield
Could you tell me how far it is from the heatsink to the side panel? Do you think it could be plausible to fit a 25 mm thick fan and a 30 mm thick single 120 mm radiator there?So the Noctua NH-C12P officially barely fits with the Asrock Z87e:
http://img.photobucket.com/albums/v608/princecupid214/Ncase M1/DSC_0777_zpsf7e05726.jpg
http://img.photobucket.com/albums/v608/princecupid214/Ncase M1/DSC_0775_zps2e69e63c.jpg
I think the top panel touches the heatsink , but barely any pressure on it.
Without the fan bracket, there's 135mm available for the CPU cooler. With the fan bracket, it's 130mm.Could you tell me how far it is from the heatsink to the side panel? Do you think it could be plausible to fit a 25 mm thick fan and a 30 mm thick single 120 mm radiator there?
From the pic I'm estimating that there's only around 50 mm or less of space but it would be nice to know for sure with a proper measurement.
Wow
I am shocked to learn that Necere doesn't have a case yet.
I thought you'd be one of the first....with a cool dedicated serial number and all.
Same with res and adamantium ? Why no love for the designers
He must have a case or he wouldn't of been able to do the different cooling setup reviews
I still have the first prototype, actually, though it's not in an entirely usable state (had to transplant the cables to the 3rd sample, which went to The_Cheese). The second sample went to w360 for evaluation (that's the one that had subpar exterior panel edges due to NCT vs. laser cutting).He had the prototype (or prototypes) for a period of time for testing before the 2nd IGG campaign began, but has no case of his own currently. The_Cheese now has the prototype for his generous contribution, and if there were others, they were probably sent back to Lian Li.
I agree that Necere & W360 should have received early VIP cases, mostly as a perk for their hard work, but also so Necere could have done earlier test fitting on the Demci filters, as well as for reference in answering others' questions (ie, screw identification).
I can't blame him. He's got his hands full as is with replacements for damage/defects, or the few people that got the wrong color.
It's true I should have had one of the production cases air shipped to me so I could sort out the filter business and whatever else...
Los Angeles, CA here. Still no case or update to the tracking number.
can't help but feel a bit saddened to see new M1s popping up on ebay at a steep premium.
