Phuncz
- Apr 12, 2009
Ah your problem was with the fittings. I didn't get that from your post. My issue is because some 90° fittings might be be wider than will fit because it only has a millimeter or two.It doesn't mater if small changes have been made since that render, and it doesn't really mater if the R9 290x or water blocks were available or not because all reference video card PCBs are the same height meaning most water blocks are the same height as well, Its pretty obvious you need to use 90 Degree fittings or the hoses will hit the side bracket, Also you can pick up a frozenq Reservoir so who cares about the one in the render.
Necere already mentioned multiple times this is not the case. Read the last few pages.All full cover blocks will fit as long as the PCB hasn't been changed from its reference design.
