wahaha360
- Sep 8, 2012
To be honest, Necere is not offended by it.
We are not getting ANY kickback from Lian Li.
lian li might have ripped them off but it is way inferior to the M1. there are other screenshot here http://www.lian-li.com/en/dt_portfolio/pc-q35/ there is one tiny vent in the top. one on the bottom. none on sides. the psu is placed above the cpu area. i wont even get into the intern differences but they are shown in the pictures
How about a Steambox/HTPC M2 case as next project
Only air cooling ... GPU with riser card ...
I would buy the fuck out of that.
I have been looking for a flat-factor HTPC case that looks at home with my AV gear.
You know, the more I think about this layout, the more I think it will have heat problems. The reason they can do it with the Steam Machine is they're able to limit the component choice which allows them to design ducting specifically for those components. That's not really possible to do if you need to design a case to work for many different GPUs (blowers/non) and CPU coolers/socket locations.
well em ...
And that is supposed to fit on my desk... how?
HTPC / Steambox
From another thread, FYI...
A cube has the biggest ratio of volume per square inch of metal, so it has the biggest ratio of volume/bare weight. Flat rectangular boxes like X51 will naturally have the lowest ratio of volume/bare weight, so I personally don't like such cases. Yes, I know I'm the only person who cares about the weight.
I've addressed this before. It's just an issue with some ATX PSUs, unfortunately. The best I could suggest is to try flipping the PSU the other way, though if the inlet is centered it won't make much difference.Has anyone tried to fit an ATX PSU into M1? I have a Seasonic SS-400FL2. I can fit it into the case with the shipped ATX PSU mount bracket, but when I try to connect the mains I got trouble. The mains cable in the case comes from the wrong direction. I can push the cable into the bracket with a lot of pressure (I won't do it again as it may break the wires inside), but then I cannot attach the mounting bracket to the case: the small plastic cover holding thingy will not allow it.
There is none.BTW is there an online assembly guide to the case as I don't seem to have one in the box.
Now this is completely unexpected, a word of caution would have been nice
Is there a way to replace the M1 power cord? I do not want to open the PSU as we talk about a brand new one and this would say goodbye to the warranty.
Or is there a fanless SFX PSU available?
Take a look at ncases.comPower supply:
SFX up to 130mm, modular or non-modular.
ATX support via included bracket is limited to 140mm non-modular PSUs with cards longer than 200mm. ATX PSUs are not recommended due to limited room for long cables.
It's true, it'd be useful to put that note in there. Though, prior to people actually finding it to be a problem, it wasn't something we could know. We couldn't exactly test dozens of different PSUs. I did ask for people to provide feedback about that in the spreadsheet. Edit: actually that was a different issue. But the more stuff checked, the better.I looked before I bought the PSU and it does fit the specs. The problem is not the specs, but the lead-in socket placement. And that's not written anywhere. Like "Warning! ATX PSUs with their lead-in close to the edge will have trouble fitting!"
Is there a way to replace the mains cable in M1? Or where can I buy an angled plug that bends in the other direction? I'll have the neighbor solder it for me (he's an electrician and owes me big time )
The issue is that virtually all of the commonly available plugs are too tall. We went out of our way to source a plug that was low profile for the M1.You need a IEC320-C14 Male Panel Mount plug (this is the part that mounts to the back of the case) and IEC320-C13 Female Left Angle plug (they also make up and down angle but they are harder to find).
I attached an image to illustrate my problem. The cable should obviously come from the other direction but then it can't fit.
I believe you are correct. As long as you don't mind voiding your warranty and are handy enough with a soldering iron. This probably what I would do. But I've got a surplus of the left-hand plugs from a previous project. Either way, it is an easy fix.It may not be for the faint of heart, but on some psu's, the input power jack might be flippable to the opposite direction with some disassembly. That seems to be the easiest and cheapest route.
It's not a problem that you didn't think of that in advance, because you thought of a gazillion other issues and solved them perfectly. But if you could put a warning on ncases.com NOW, that would make things clearer. At least for those who haven't invested in a PSU yet. BTW I still love the case despite of this issue.It's true, it'd be useful to put that note in there. Though, prior to people actually finding it to be a problem, it wasn't something we could know. We couldn't exactly test dozens of different PSUs.
Both plugs are too high. You can't put the top of the case on with them.
