slabhatnik
- Sep 19, 2013
Not 100% sure, but I don't think there are any mounting holes for a 2.5" drive in that location.
You might still be able to squeeze one in, though. With a 3.5" drive mounted in the back, there's still enough space front-to-back to mount a 92mm fan.. so you should have at least 120 x 92mm space available. A 2.5" drive is 100 x 70mm, so I can't see why it wouldn't fit. Might need to mount the drive with double-sided tape or velcro, or maybe drill new holes.
EDIT: Forgot about the cables! Not really sure how much space would be used up by data & power cables for each drive. 20mm space for each still seems like more than enough, but not really sure on that.
Cables were more my worry. I figured I'd make a bracket for the base- adapting the 120 or 92mm holes to something like the LL rubber grommet slide mount holes; I have so much Lian Li here I could probably cut some mount out of something and make a sweet little bracket for the spot....
