- Jul 15, 2013
Suggestions for a high performance and long term cooling fluids would be awesome.....noobies to h2o need this info (yeah that includes myself)![]()
Distilled water
Could you link the fittings you are using for the reservoir ?
CHEERS!
Hey Zoob, unless you shipped to another address, I don't think you'll get the free shipping deal. It was only for US (lower-48), and in the M1 spreadsheet it says you're from Canada.
Drklu & S0skey should, if they can straighten everything out.
Awesome! Thanks AFD!
Just checked it and they want 8.78 for shipping, so maybe the free shipping part has ended?
I haven't ordered yet, $ is tight at the moment with heating season ramping up.... gotta sell something on ebay fast i guess!
Same. Shoot I guess I should have pulled the trigger a week ago
Sure thing, I'm just glad they're willing to make things right. He told me that everyone that qualified for the free shipping would be credited, and that the free US shipping option should be fixed sometime tomorrow.
Due to this mix-up, he extended the discount codes for an additional week.
Should be straightened out tomorrow. There's now 1 more week left for the ODD deal..
http://hardforum.com/showpost.php?p=1040314284&postcount=6277
Digistor was also having problems with its free shipping option a few days ago. However, I emailed them before completing my order and Larry politely and promptly replied, assuring me that it was an error that they were working to fix. He told me that if the site still didn't show free shipping when I placed my order, he would manually process a credit. However, when I returned to place my order, free shipping was working. I received the blu-ray drive this morning. It was a California delivery so it only took one day to arrive.
They have been very responsive.
Anyone else planning to add a little AcoustiPack foam to the sidepanels?
Not sure how effective it would be. The material in my Fractal Design cases has always been nice, but I doubt very much the small amount of available surface area for foam in the M1 would be effective at dampening.
I'm still going to try it, though.
EDIT: I'll probably cut up an extra ATX PSU rubber gasket to fit the SFX bracket. Can't hurt.
Same here. Except... Waiting for PSU for 2 weeks nowGreat, now i have all parts except for a GPU laying aroung here and no case to stuff it into![]()
Share your Ncase receipt status
https://docs.google.com/spreadsheet/ccc?key=0AuQJbc_Aru20dDdLbmJWMjZYSXJvNWNOVzJkdkJPTWc&usp=sharing
I'm sorry if this has been answered before, but how much space is there between the Apogee Drive II and the radiator?
I'm trying to figure out if a 38 mm radiator with a 25 mm Gentle Typhoon will fit.
Edit: See this post
Just got my customs letter through the post (UK) I've paid the invoice and my M1 should be with me tomorrow.
Excitement got to much I'm off to Parcelforce to pick it up.
Perhaps if panels are resonating it will help a little, but I think vibration damping like on the PSU will be more useful. Otherwise I think the key to low noise is going to be minimising airflow restrictions and choosing an S or T series CPUa little AcoustiPack foam to the sidepanels...
...Not sure how effective it would be.
That is outrageous, how the fuck is that justified?! It costs less than that to deliver a parcel within the UK! I'm used to paying around £8 or slightly more but I can't remember ever paying that much for clearance.Clearance Fee (Zero rated for VAT Purposes): £13.50
I also found a post that Parcelforce refused to answer a freedom of information request for a breakdown of the £13.50: here & here"Goods to be Customs cleared by the importer"
Those renders are helpful, but the biggest height issue about the AD2 is not the height of the pump or heatsink (which you can remove), but the height of the fitting which goes on the outlet port.
So first you need to know which orientation you will put the AD2. Then you need to know where the outlet port needs to connect to. Then you can maybe angle the outlet port one way or another (it moves +/- 30 degrees). Then pick an appropriate short 45 or 90 degree rotary fitting... and only then will you know the maximum depth of the radiator.
Incidentally, the shortest 90 degree rotary available is this one: http://koolance.com/fitting-single-black-swiveling-elbow-low-profile which is 17mm (effectively 20mm)
I'm waiting to get the case before making any more assumptions about radiator and fittings.
Wait, what? This didn't work for me..
Guess I'll give it another shot
mine is the same amountsAlso just got my customs letter through the post.
Import VAT: £19.89
Total: £33.39
For anyone intrested the costs's are:
Import VAT: £19.89
Total: £33.39
#650 arrived
Mine costs were
Import VAT: 10.91
Clearance Fee: 4.50
VAT: 38.54
Total: 53.95
I'm starting to hate my country...
Anyway, BIG THANK's for Necere and wahaha360 !!!![]()
Yes, it has Commercial Invoice from Lian LiDoes it come with some sort of customs declaration or invoice?
Are we going to have a builds thread eventually on this? I'd love to know what works, what doesn't before I buy my gear!
It's pretty awesome how many EU citizens we have on this thread getting this case.
Anything made for cars probably smells a lot stronger than stuff made for PCs. The smell normally goes away after a while, but some people say it makes them feel sick.I was thinking about getting a small order of Damplifier, and trying that. It's a thin, lightweight vibration dampener used in car audio installations to prevent harmonics that occur when the car's sheet metal vibrates. I was thinking that a small section applied to the lower half of each side panel might help stiffen them up just enough to stop any resonance from fans or hard drives.
I might have to check around the SPCR forums and see if there's something similar, but more suitable for HTPC applications. Do you think the AcoustiPack would do okay reflecting heat, or would it actually absorb and trap it?
well we have a spreadsheet over there for cooling solutions mainly:
https://docs.google.com/spreadsheet...bmJWMjZYSXJvNWNOVzJkdkJPTWc&usp=sharing#gid=6
but we need more input on actual builds![]()
