drklu
- Jul 15, 2013
Both my rigs have a ST45SF-G sleeved.
It's difficult to describe without pictures, but think of a door handle. Normal door handles are a mirror of each other. If they were both exactly the same, then one of them would pointing the wrong way. Or you can turn it upside down, but then you have to open the door by pushing upwards. PSUs in the Silverstone Strider connectors are similar. The connectors on PSU side and MB side have exactly the same pinout. But because the sockets point towards one another, the wires all have to cross from one side to the other column-wise, while keeping the same row (mirrored). Or you turn the PSU upside-down and cross wires from one row to the other while keeping the same columns (interlaced).
Happily, in the NCase M1 the PSU points down and the motherboard towards you. So you'll have a natural curve so you can go with interlaced which looks a bit nicer.
Thanks for your helpful analogy WiSK. That makes much more sense. I can't wait to start sleeving, I'm going to get the material and get some practice in on my current rig in my signature.
Again, thanks for you help.
