It's against forum rules
How do you see what number you are?
I thought the serials were going to be randomized anyway. Supporting the team and getting it made is what matters to me, the serial number is arbitrary.
Didn't get an email either.
Also don't you think a link on the first post to the Actual page where you can buy one is needed? If you use the link supplied you are taken to the prototype page where there is no mention the campaign is live. Only by hitting the updates link was I able to find it. Could just be me, but maybe needs to be easier to find.
Yeah this is a good point, would you guess the cpu and mobo would be the same block or are we talking just the mother board? They say it's a "full cover" block so that sound's like it cover's everything. Does that include ram as well? If so I think this would be a good solution though I do feel your concerns with dropping more heat to an already stressed cooling system. My plan was to get the highest quality rad/fans to push the single rad to the highest efficiency possible.
Correct me if I'm wrong, but if you added an extra 20mm below the third expansion slot, wouldn't you have enough room for a slim 240 rad (30mm) plus fan (25mm) to fit below a watercooled graphics card?
Are you suggesting the case should be modified a few hours after the production campaign went live ?
Trying to convince myself not to buy two...
It hurts so fckn much to be from eu, seems like this case is gonna cost me about 300e
I think it's a great idea for a potential future version. It would increase cooling capacity and allow for lower fan speeds. With a powerful enough SFX PSU, serious overclocking would be possible and the lines between mini-ITX and larger form factors would be blurred even further.
There are some 30 odd people that have not chosen a pledge on the campaign. What is going to happen with them? That really is going to need to be worked out.
Actually, think fully modular ATX PSU, slim 240 rad at bottom, *snip*
Man only $8k away from funding. Necere & Wahaha... you guys killed it, congrats!
So we're just including LL's standard plastic-frame filters that bolt to the fan.
To have a fully modular ATX PSU you have to add space to the top and shift the board downward or the PSU up. If you just add the space to the bottom you have room for your rad and fans but the PSU to card distance remains the same. You have to add it to the top AND bottom for a modular ATX and room for a rad.
So now you are looking at 14.7L vs 12.6L or a 2.1L increase assuming 40mm added overall. (20mm top to allow for 160mm ATX psu w/ modular connectors + 20mm bottom for rad and fans)
...I would say that should everything go normal M1 boxes will start arriving by Christmas the earliest. More likely 1Q2014...
this case is AWESOME and i'm sad i have no use for one. :/
$63,000 in only 19 hours. Unreal.
I'm still trying to resist also getting a silver one. I have so many expensive cases I don't use. PS4 and Xbox One on preorder and I'm getting laid off in a month
edit: I ordered the silver one too. No more thinking about it for me. I'm free from my obsessions now
#43 black #271 silver - I think anyways.
So for $205 I can buy this case?
After January will they make more for mass shipping or is it just this limited time only then they are done?
Are they doing revisions anymore in the future to improve the design or is this it?
Thanks
Just hit 300.
I'm showing 285 ???
