First off, hello all, this is my 1st post. Been lurking awhile, but always found what I needed without posting until now..
So, Im at a cross roads with my Ncase. Problem is: Heat.
My current setup is:
Ambient temp is always 70F
X34 Predator monitor @ 100hz
Z170 Pro gaming w/e
6700K mild OC
SF600 PSU
Titan X pascal
2x 8gigs dominator ram
4x Noctua NF F12? (High pressure 120mm) 2 under GPU poiting towards it, 1x per radiator (see below)
Current Cooling config, which is yielding great temps under all clocks (4.4 on cpu 2k on gpu), however, isnt as "cool looking":
Corsair H75? (Small unsleeved rubber tubes) for the CPU: Max temps Ive captured is maybe 75-78c after many many many hours of 4k gaming
GPU is cooled by a modded 1080TI hybird kit, which cut the temps almost in half from the stock cooler. (86c to maybe 58c, hell ive idled @ 13c for hours) This cooler is actually awesome for the titan and the titan does not thermal trottle period anymore.
I was trying to get my temps even lower, so I ordered a full loop from EKWB consisting of:
Supreme EVO? copper block ( the 75 dollar one)
Full gpu cooper block and backplate
240mm SE? slim rad
EK-XRES 100 Revo D5 PWM pump combo unit
all accosiated hardware / Compression fittings / 3/8-5/8 ID/OD Soft tubing
Mounted like this:
Rad is under the GPU, Slim noctua fans AX? something or another pushing through rad towards floor
Pump is mounted vertically on the front inside panel in custom drilled holes.
Loop chain is:
Pump our -> CPU in -> CPU out ->GPU In? (Hole closest to where you plug in the HDMI Cables/Display port) -> GPU out (other hole) -> rad in -> rad out -> Pump in
Issue is the temps are absolute garbage in the custom loop. I mean, literally soon as I boot up the CPU/GPU is 35c- Start prime95 and CPU hits 100c instantly. 5min of game on the GPU is upto about 70c again.
I have since uninstalled the custom loop and went back to the the 2x closed loop AIO which are performing wonderfully. What did I do wrong in the custom loop? I resat the CPU and GPU twice which fixed nothing, I bleed the air for 24hours, everything looked rock solid. Im clueless...
Is my setup to much for a single slim rad and thats why the individual rads are working better? The AIO rads are mounted on the horizontal bracket below the CPU but above the GPU.
I feel like the custom setup should performed way better but in the 3x different removal and installs I did did nothing.
hellppp!!
Z170 Pro gaming w/e
6700K mild OC
SF600 PSU
Titan X pascal
240mm SE? slim rad
Mounted like this:
Loop chain is:
hellppp!!
