I have a nappit all on one setup with esxi/omnios and Im having some problems with permissions for my windows shares.
I have two ZFS file systems, a vmshare that is an NFS/SMB share and a general data partition.
Im using the system in home environment and dont care about setting up file permissions so I opted for simple settings during setup, guestok option I think it was . I have been able to access the SMB shares from windows and read/write to the fs with no problems until recently.
I have an NFS share that I use for my vm storage and it is also shared as SMB. Im trying to create a backup of the share files through file copy in windows but getting permission problems when I try to copy the "-flat" disk images. For these I get a warning:
"You require permission from Anonymous to make changes to this file"
This happens only for the disk image file, other files in same directory are ok. I thought I had enabled guest access for the entire partition so not sure why it is getting stuck. Also windows does not prompt me for login/password so no option to login as root.
I have to admit Im not up to speed with windows permissions and how to cross map permissions between zfs and the windows file system.
Ideally I would like to know how to set up a file system with:
o) Global shares accessable to everybody on windows with no password.
o) Private shares that requires password/login for some protected files and a way to authenticate on windows with the login/passwd.
Dont want to pay for pro version nappit with ACL support, just looking for how to setup some permissions without active directory. Im guessing that I could probably do the admin directly on solaris by editing some files/commands.
Appreciate any pointers as to how to get started.
Kuma
Kuma
