Myopia, small room and HTC Vive
David-Duc
I'm thinking about getting an HTC Vive. However, my eyes are -4.0 and the room is also kind of small. Do you guys have any idea on how would that affect my experience? Am I going to have to wear my glasses while playing? Is it comfortable?
The PC is not going to be a problem (6900k + 32GB Ram + GTX 1080).
My eyes are -2.5, -2.7, so I play with glasses on. Things are just clearer. Unlike the Rift, my glasses fit comfortably into the Vive. Occasionally they'll get pulled off when I take the Vive off, but it's no big deal. You have options though - VR Lens EU makes the best corrective inserts or you can buy a small, cheap pair online at a place like Zenni Optical.
How big is your room? My office's playspace works out to 6 ft x 10 ft, so on the smaller side. It works but you'll be using in-game locomotion a lot. Some experiences essentially have no locomotion options and won't work, but Steam will warn you if your playspace is too small. I move my VR rig to the living room for VR parties or days off because that space is much larger. It's just better.
I'm nearsighted with astigmatism and have no problem playing the HTC Vive without glasses. My vision isn't as bad as yours (-1.75/-1) but give it a shot with both. See if you can go to a windows store that has a demo.
My left eye is trash my right compensates for the vision loss in my left. I can see out of it but my fovea is heavily damaged so I have very little center focus.
I have no big issues on my oculus rift so I can't imagine that you would have issues with your vive since they essentially use the same style lens technology inside them if I am right .
