Well, I was serendipitously able to obtain a copy of Doom 3 early and I figured that I would post my initial experience of the game with both of my systems. You can check out the sig for the specific hardware info.
System 1:
I installed and loaded up Doom 3 with no problem. Menus looked good, but alas it was too good to be true. As soon as the in-game intro began (using the game's engine), I noticed white dots flashing randomly all around the screen. This random 'snow' continued during the actual game. So this is what Carmack was warning all of us overclockers about!!! I couldn't deal with the "snow", so I was forced to downclock my 9800 Pro back to its stock speed. After that, the game ran flawlessly.
1280x1024x32, high quality -- Nope, way too choppy, I'd say for everyone
1280x1024x32, medium quality -- Playable, but definately jerky when the least bit of movement begins onscreen
1024x768x32, high quality -- Playable, again a bit choppy for my taste, but playable
1024x768x32, medium quality -- The [H] was right, this is the sweet spot for this card
System 2:
The install and load went fine. Happily, no white dots on this card (not overclocked, go figure). The load times were definately a lot longer on this system, probably by a factor of two.
1024x768x32, high quality -- Unfortunately, not going to happen
1024x768x32, medium quality -- Playable, but too choppy for my liking
800x600x32, high quality -- If I had 256mb onboard, this might happen
800x600x32, medium quality -- Again, the sweet spot
Conclusions:
The game definately looks quite a bit better on the 9800 Pro system. Previously, I was unable to detect a major difference between the on-screen quality between these cards. Clearly, the Ti4600 is likely to fall behind from here on out. This is not to say that the game looks bad. On the contrary, the game is stunning in both 800x600 and 1024x768... obviously it is slightly MORE stunning in 1024x768.
I was waiting on my upgrade until I actually saw how my rig was going to perform on Doom 3. Now with that in mind, I've decided to take the plunge and order an eVGA 6800 Ultra. Seeing this game in medium quality just enticed me enough to want to see it in high quality at a much higher resolution! It's that freakin' cool.
For those without the means or the want, I would say that the game is entirely playable on both the 9800 pro and the Ti4600...... it's just a question of how badly you want the game to look even better than it already does....
Side Note: The gameplay itself is highly reminiscent of System Shock 2..... odd
System 1:
System 2:
Conclusions:
