My sys vs A64 2.6ghz
OblivionLord
I cant find any ingaming benchmarks for A64s vs P4 anywhere. I can only find timedemos and botmatches which mean squat to ingaming. Anyone know a site that does compare a simular system like mine to a A64 @ 2.6ghz doing ingame benching?
My 3dmark01 score is 23483 for stock xt-pe speeds and 23906 @ x850xt-pe speeds (540/590). On furturemark there are alot of people with my card at stock speed on oced A64's at 2.6ghz getting on the 30k mark in 01. Basicly thats 6k diffrence. I'm sure this means a great deal for ingame benching.
If noone can find a site that has ingame benching comparisons then I'm willing to download game demos to see results for a fair comparison. Problem is somone with an A64 at 2.6ghz with my card will have to be willing to bench with me.
Thanks
smercer
I have a 64 939 3500, I am currently running it at 2.4ghz but have oc'd it closed to 2.6(2.56) the only prob witht that oc'd ws that i am only using air so the load temps went a little to high to be safely running it. But i could run my system at it for a little bit to test it.
I have the Saphire x800xt pe. Just tell me the test that you want to run and i will get them and see what the results are.
OblivionLord
Awesome.
I have UT2k4 which is very cpu dependant. If you dont have the game and are willing to dl the demo then Im all for it.
I also have Farcry but, im willing to download HL2 and Doom3 demos. Just get back with me and we can go from there. If you want you can prvt msg me.
Just wondering ... what are your load temps at 2.6ghz and what HSF are you using to accomplish this?
arentol
Absentee
OblivionLord said:
Awesome.
the graphics in the ut2k4 demo are toned down a bit...no lights on cars. etc
OblivionLord
Timedemos are prerecorded like you said which are basicly scripted benchmarks without any variances. Same applies with botmatches. Therefore neither will show the same results as ingame performance. Example.. when you have 32bots on screen with variable calculations, its going to put a hell of alot more strain on the cpu than a timedemo with the same number of bots since all of it is predetermined. Timedemos and botmatches are nothing more than synthetic benchmark results just like 3dmark. No variances or nothing.
Sucks that the demo doesnt offer alot but, even at its highest settings it still can show a diffrence between systems.
smercer
I got a 5880 score in 3d mark 05 ( sorry i have been really busy to do the test but as soon as I can i ill give you the results) By the way what is your score?
OblivionLord
3dmark05 is heavily GPU intensive which is how I got around the same score as you
05 = 5855
This UT2k4 ingame bench will deffinently show a diffrence since its heavily CPU bound. I sent you a prvt msg about how to performn the ingame test. If you could Id like to see results. Thanks
chipmonk010
why not use sandras arithmatic benchmark since it just tests the cpu....i get
10931 MIPS
3894/5043 MFLOPS
with my s939 90nm 3000+ @ 2.4ghz
DryFire
maybe i can get my s754 3000+ to 2.5-2.6ish when i get my wc'ing in (should of had the remaing parts today :( ) I doubt my ram will go that far though.
woudln't super pi or something be a better test?
chipmonk010
3d mark is more of a graphics card test....if someone has a better video card and a slower cpu they could still outscore u. if you want to know if your cpu is running fast or slower then arithmatic benching is the only way to go. btw 3dmark is a synthetic benchmark....
super pi is also a good one it realies alot on ram aswell tho not just cpu.
OblivionLord
Im mainly interested in ingame benching since I do alot of gamming. There just isnt any luck for me to find sites that does ingame benching but, only botmatches and timedemos.
Stoopid Guy
The difficulty with 'ingame benching' is that unless it IS a demo, like CS:S's, there is just about no way of doing EXACTLY the same thing on two computers, unless I am being stoopid here :D
