Unabomber
- Jan 1, 2005
A while ago, I was experiencing video freezing problems with my system. Basically, whenever using any fairly intensive Direct 3D or OpenGL application, the system would occasionally hang, resulting in the screen freezing, and the same sound playing over and over, for about 15 seconds.
Imagine the frustration that came about, when playing in Team Fortress matches...
Anyways, it seems that the power supply has proven to be the culprit.
My stats:
Asus A8R32 motherboard
Opteron 146 CPU (running at 2.5 GHz)
2 GB Crucial PC3200 memory (2x1GB)
BFG GeForce 7900GS PCI-e video card (256 MB)
XClio Goodpower 500 watt power supply
and a few other peripherals.
Now, according to XClio's stats, the dual 12 volt rails on this unit are supposed to supply 16.0 amps on the 1st 12 volt rail, and another 17.0 amps on the 2nd 12 volt rail. Thus, with this much power available, I would have thought that I shouldn't have any problems with my BFG GeForce 7900 GS video card, which BFG recommends a minimum of 22.0 amps on the 12 volt rail.
Unfortunately, it seems that either there's a lot of efficiency lost when both rails are combined, if my understanding is correct.
The only way I could cut down on the number of system hangups (to a very low number), was to reduce my CPU's HT speed to 800 MHz, and to run my CPU back at stock speeds. Normally, the 2.0 GHz is plenty fast enough for my purposes, so that wasn't too bad of a hassle, but I just hate keeping my stuff crippled...
Anyways, I've just ripped out the old Antec Truepower 480 watt (single rail) unit from an older computer (supposed to be able to give 28 amps on the single 12 volt rail), and now find that the hangups are gone. I've just ran one of NVIDIA's demos for a good while, played NWN2 at the highest settings possible, HL2 at aggressive settings, and BF2, and not a single hangup.
Then to be daring, I've put my CPU's HT speed back to 1.0 GHz, and restored the overclock to 2.5 GHz, and still haven't had any crashes or hangups with this old power supply.
My question to all of you who own the XClio Goodpower unit is this: Do any of you have this power supply stably running something similar, or even more powerfuly? If so, what are your specifications?
If it's not possible to stably run this system with this unit, then I'll be ordering a Seasonic later on, but for now, at least I know that my old Antec can still get some good use.
My stats:
