My "Show" Build: Hard Line Watercooled/5 GHz/RGB/Android monitor/P5 open case PIC HEAVY
chief3630
Thank you for checking out my build! More pics below, or here: http://imgur.com/a/xFLZx
First watercooled rig. First time overclocking. Second PC build for me. Many parts were reused from my previous build and bought on sale. Used for daily work (teleconferencing) and 4k 60hz gaming. I also do some photo editing in Lightroom. Mostly just for me to look at and admire all day while I work!
PC Hound Part List
CPU: Intel Core i7-6700K ($324.89 @ Amazon)
Motherboard: ASUS ROG MAXIMUS VIII HERO ($171.53 @ B&H)
Memory: G.SKILL 16GB (2 x 8GB) TridentZ RGB Series ($144.99 @ Newegg)
Video Card: EVGA GeForce GTX 1080 08G-P4-6286-KR 08G-P4-6286-KR ($544.98 @ Newegg)
Power Supply: EVGA 1000W SuperNOVA 1000 G2 120-G2-1000-XR ($149.55 @ B&H)
Various watercooling parts; CPU block, pump, resevoir, fittings, valve, stopper, PETG tubing $300
XSPC RX480 Radiator $100
Aigo RGB 120mm fans (5x) with 2 LED light strips and wifi controller $90
Bitfenix sleeved cables $65
Storage: SAMSUNG 512GB 950 PRO MZ-V5P512BW ($318.99 @ Best Buy)
Storage #2: Crucial 1TB MX300 CT1050MX300SSD1 ($279.99 @ Amazon)
Storage #3: WD 750GB Blue WD7500BPVX ($49.99 @ Amazon)
Case: Thermaltake Core P Series CA-1E7-00M8WN-00 ($149.89 @ Amazon)
Windows: Microsoft Windows 10 Pro 64-bit ($132.98 @ NCIX)
Mouse: Corsair M65 ($49.99 @ Amazon)
Keyboard: Corsair K70 RGB ($192.7 @ Amazon)
Headphones: SENNHEISER GAME ONE ($154.99 @ Best Buy)
Corsair MM800 RGB mousepad
Total: $2,665.46++
Price may include shipping, rebates, promotions, and tax
Generated by PC Hound
It was a blast to learn about watercooling and put this together. It all started by seeing the Thermaltake P5 case and the amazing builds people have put together out there.
I loved the look of the EVGA FTW and so I wasn't tempted to watercool it. It also runs at a great OC at around 60 C on air.
My pipe runs are not efficient nor direct, but that was not my goal. I planned it to be visually unobstructive of the other components, and pleasing to my eye. I liked the look of the 90 degree fittings in other rigs, and didn't plan to do many bends myself, but in the end I had to put some in, and I am very happy with how they turned out. The pictures make some of the horizontal runs look a bit slanted, but in person it is not apparent.
Currently running distilled water. Plan to drain in a few months and possibly switch to Mayhem's pastel either white or blue.
The android phone is attached with a velcro strip so I can remove it and take it with me for monitoring stress test runs, etc. from other rooms. I can also control the fan speed, RGB lighting, and boot/shutdown from a different app on the phone.
The SSD is vinyl wrapped to keep it a bit stealthed, but still clearly not part of the case.
The drain plug has a wrist watch movement displayed, which ties it into another one of my hobbies; watch collecting.
OC'ing the CPU was alot of fun too, and I'm pleased with the result. I was able to boot to windows at 5 Ghz @ 1.44 V but it crashed on the first test run on Cinebench. I am going to read up more and try more tweaks to get stable at 5 GHZ. It passed stress testing at 4.9 @ 1.44 but the temps were 75 C max so I decided to drop back to the current OC 4.8 at 1.32 V for daily use.
I'm interested in hearing your comments and recommendations. Eventually I'll pick up a 1080 Ti reference card to add to the watercooling loop. Any tips on settings to tweak for a stable 5Ghz OC?
PoseidonPC-40vin by chief3630, on Flickr
PoseidonPC-39vin by chief3630, on Flickr
PoseidonPC-38vin by chief3630, on Flickr
PoseidonPC-45 by chief3630, on Flickr
PoseidonPC-44vin by chief3630, on Flickr
PoseidonPC-47 by chief3630, on Flickr
PoseidonPC-48 by chief3630, on Flickr
PoseidonPC-46 by chief3630, on Flickr
PoseidonPC-49 by chief3630, on Flickr
PoseidonPC-52vin by chief3630, on Flickr
PoseidonPC-51 by chief3630, on Flickr
PoseidonPC-50 by chief3630, on Flickr
PoseidonPC-22 by chief3630, on Flickr
PoseidonPC-10 by chief3630, on Flickr
D
Deleted member 88227
Guest
Dang that looks good as hell.
I want more details on the android app.
horrorshow
Here's something you don't see everyday....
Did you write that Android app yourself?? (aka, where the hell did that app come from. I can't find it on Google but would love to run it myself)
Regardless, supercool sir!
chief3630
Thanks, and I wish I was able to write an app myself...
It isn't so much an app, as a feature built into Aida64 Extreme called remote sensor. https://forums.aida64.com/topic/2636-remotesensor-lcd-for-smartphones-and-tablets/
Basically it creates a webpage based on the sensor readout you design inside the program. You can point any browser on your network to the computer's IP address and port number and the webpage will show up.
I do use a few apps to make it easier to display on android: "full screen browser", "no lock", and "screen on".
The hardest parts were opening a port through windows firewall and my router (I don't have much experience with that), and getting the webpage designed how I wanted it to look. There are many options.
Armenius
Nice clean build. The lighting was tastefully done, and everything fits together. I love the look of that CPU block.
