My Rig
l337*g0at
Not much modding to it. Only dremeled a top exhaust, took off the door, cut out the middle/ going to add some glass to the door.
I will show that off when I get done. Dremeled some plexi from the window to add a fan like the new chenmings have.
Anyways, this is my own webspace, so you can click on a link, i suppose.
Mods : Make my link un-clickable if it is against the rules.
http://www.gi-clinic.com/jaz-z0r/Computer/
It could use a little bit of wire stealthing...A "little" bit messy, I think.
The drives look like they should be painted to match the case, but quite nice otherwise.
