Hey, thought id post some pics of my "build." not really a build right now, more of a swap over from my old stacker 832 to this new case. i will eventually be modding this Raven with custom paint, and a watercooling setup with new mobo/ram. i will be stuffing a 4x120 rad in the middle where the 2 180mm fans are right now. more on that when its time though. onto some pics
side by side comparison to the stacker
cable management was not that easy. it took some good time to get the cables right so they look nice. needed to be creative in order to get everything to look good. i will be sleeving all the power cables, and they will all be well hidden once im done. i will be using all black cabling as i did for my SATA cables, so it will be very hard to see any cables at all once im done. i will run the power for the video cards along the middle bracket that is removable with the 2 thumb screws. ill get some pics up once im done sleeving to show what i mean.
i had to under volt the s-flex G's in this case to 7v to make em quiet. they were not noticeable in the stacker as there was 7 fans in that thing (not including the 2 push/pull), but this raven is silent and the s-flex's got too loud. i used a 3 pin to molex adapter that came with my ap121 fans. they allow you to plug in the 3 pin into a 12v, 7v or 5v connector to under volt without the use of a fan controller
swapped out the stock 180mm fan under the video cards for an AP181. the 2 fans are identical, but the ap181 has that grill that makes that 1m vortex effect.
here are all the fans i bought for the water cooling. wanted to test out this new AP series. 4 non LED ap121s, 5 red LED AP121s and a single AP181 that will sit directly infront of the PSU once the 4x120 rad goes in
thanks for looking, all comments welcome
