Monkey34
- Apr 11, 2003
Well, like a dope, I havn't backed up in a while. I was preparing to do one, and (dumb idea) wanted to "clean house" before hand.............instead of just DOING IT.
I had a small partition at the end of my disk I have wanted to get rid of a loong time ago, so I thought I'd lose it now, so if I need to install from backup, I wont still have it around.
I happened to be using Partition Magic 2002 (has always worked before). Normally I would do this in 2 steps........delete the partition, and recover the unallocated space second - but for some reason I chose to "merge partitions". It started, and gave a quick error about copying a file at the end. After re-boot, I got a bsod stop error. After next boot It acts like the disk isnt there. I am assuming the patition table or the MBR is messed up. I can also assume the files are all still there, so I'm not freaking yet.
Should I start with the MBR - maybe try fdisk /mbr to rewrite it? I'm not sure what it really does though - is it using an internal backup of the MBR?
I'm not concerned with the second small partition.....it didn't have anything on it of importance, just some school files that I could care less about - but the C drive is what matters.
What would you reccomend as a first step?
