Room temp, how each was applied, its also only on a single core and about a 1-2C change.
The CM also uses a 2400rpm fan while the D-14 uses a very low speed and as such quiet 1200rpm fan assuming you are running the fans without the U.L.N.A., and only 900rpm if you are.
