**EDIT - partially based on a wrong first impression... read further down for a more informed impression. **
So, after days of watching nowinstock, and missing a bunch of times on both 1080s and 1070s, I finally got lucky and grabbed both a Gaming, and a Gaming X from newegg. Before they shipped, I canceled the regular Gaming and decided on the Gaming X for the extra $20. It arrived yesterday.
It is replacing an AMD 280x. Generally, I've been playing FO4 (at 4K, with some settings lowered), RotTR (also, I think at 4K, with a bunch of settings lowered), and the Doom demo (at 4K). The 280x has been pretty decent. I've tried playing at lower resolutions, but, my particular monitor looks pretty terrible (IMO) when playing at lowered resolutions (even ones that are even multiples, like 1920x1080). So, I deal with it...I'm not a settings snob.
I booted into safe mode, and ran the driver uninstaller. Installed the 1070, and booted the PC. At that point, my 4k monitor (which I moved from displayPort on the old card to HDMI on the new card) wasn't recognized as primary, so I had to deal with my secondary (portrait, DVI, 1920x1200) monitor being primary, and not properly rotated. So, with my head tilted sideways, I downloaded the nVidia drivers. Very shortly after the install started, my primary monitor sprung to life. And, oddly, it also knew the position, and orientation of both monitors...I guess the driver cleaner didn't clean that part up? Anyway. I was back in business.
I downloaded Afterburner, I downloaded MSI's gaming app, I downloaded GPU-Z, I downloaded Firestrike Demo, I downloaded Valley and Heaven.
I launched FO4. It couldn't detect my video card. Huh? That's strange. Never had it do that before (across two other cards - my AMD, and a previous nVidia). Reboot the PC. Same deal. Google tells me that plenty of other people seem to have this problem as well (not limited to this or any particular video card, it seems). I guess I'll have to manually configure that one.
Move onto RotTR. For some reason, I'm unable to make this one look good. Not as good as I remember it looking/playing a few weeks back on the 280x. My memory could be clouded here, but my son (who also plays) remembered it the same way. I tried lower resolutions, I tried tweaking a bunch of settings. Nothing great. Odd.
Move onto Doom. Very nice 4k, even nicer than the 280x which did it as well, but with some settings lowered.
Okay, so that's out of the box. What about overclocking?
I launched MSI's gaming app. Nothing. Tried again. Nothing. It won't launch. Great. I paid up the extra $20 for this card *because* of the built in OC settings, and the app that lets me use them won't launch? Google tells me that, once again, I'm not alone. *sigh*
There's enough evidence out there already that says that using afterburner is the way to go anyway, so I skip the gaming app, and bring up afterburner. First thing I do is crank up the fan speed. Nice...I can't really hear the card over my WC radiator fans, so, no harm in letting them ramp up early.
I figure I'll use firestrike as the test tool. And I run it to get baseline numbers before any OC.
After MUCH trial and error, I find that my particular card isn't a great OCer.
I set the voltage to %110. I set the base clock at +65. I set the memory at +50 (though I didn't play with it at all to see if higher or lower was better). At those settings with my fan spinning at like 60%, my temps maxed around 55.
If I raised the base clock to +75, firestrike would crash. Seemed odd since the card wasn't getting hot.
After that, I went back to FO4, and manually entered settings and got pretty nice 4k speeds. Certainly better than the 280x.
RotTR took a lot more work, but in the end we got something that seemed okay. We both left it thinking that it might have been better before somehow. (I'm considered restoring my entire rig from my nightly backups and swapping the old card back in just to solve this mystery once and for all...)
In the end, I'm not sure I would do it again if given the chance. It wasn't a large enough jump in performance. My opinion may change as I try other games, though.
I'd appreciate any thoughts on my seemingly low OC, if anyone cares to share.
Thanks!
Thanks!
