My Motherboad is only showing Red Green and Blue colors !!!
wsarahan
Hi guys how are you?
I`m having a very strange issue here
I have a X470 Gaming 7 Wifi and some days ago my RGB only works like a RGB, let me explain, the only colors that is avaiable to chosse at RGB Fusion are Red Green and Blue, if i select another color for example Yeloow it becomes orange, if i select white it becomes a kind of yellow
The color was normal some days ago, and the wrong color appears when the pc boots, before rgb fusion opens at windows
Just tried everything, used a couple of RGB fusion versions, downgraded the bios, used openrgb, nothing works
Any idea what to do?
Thanks
