My Modified Chenming(Qpack Clone)
archevilangel
Front View
Side View(Case on), replaced the plexi glass window with some perforated aluminum and put in a 80 mm fan
Slot Bracket View(More perforated Aluminum)
SoundCard/Video Card View(Notice the custom CDROM/Harddrive Bay, theres a reason for this, theres an XP120 on the other side)
CPU/Ram view(Yes the drive bay is crooked unfortunately)
did you have plans for something where the handle used to be ?
Nope, the handles just felt flimsy(especially since I removed the drive bay on the inside) and I was worried that if someone tried to pick it up it'd fall apart.
Did you remove some of the internal structure or did it come like that?
