My Lian Li PC V354 eyefinity build (In Progress)
ltcharles
OK guys so here is my ever evolving eyefinty build. Codenamed Baby Ship (need a better name but my server is called the Mothership)
Here are the pictures of the new case Lian Li PC-V354 and its inners enjoy.
1 x Core I7 950
2 x 4gig Corsair XMS3 1333MHz
1 x 60Gb OCZ Vertex 2 SSD
2 x 64Gb Corsair Nova's
1 x MSI X58m
1 x Sapphire 5870 Eyefinity 6
1 x Lian Li PC 354
Water cooling equipment.
1 x CPU W/B Copper Heatkiller 3.0 1366 Nickel Plated
1 x Pump PMP 400
1 x 120mm Radiator Black Ice extreme
1 x XSPC Reservoir Pump top
2 x 1/2 ID 90 Bitspower Barbs
2 x 1/2 ID 90 Enzotech Barbs
2 x 1/2 ID Perfect Seal
6ft of 3/8 ID Tygon tubbing
Pending W/C
240 Slim Rad
slim 120 high rpm fans
maybe 140 slim Rad if they exist.
So Water Cooled & wire management today 4/21/11
Well the temps went down like crazy from idle on air of 115F to 95-99F and never passes 139F on load. Love it love it and on a side note this is done by 120 rad with a lame stock lian li low seed rpm. Once i change those to high rpm fans I might drop the temps some more.
Will post pics of the inners once i start the w/c part of the build.
if any of you guys or gals want my old rads pm since i cant post here about that matter.
stalkerte
[H]Lite
Could you please list out the parts you are ordering for WCing?
PS - this is a great looking build :)
flampy
if you're using an x58 w/ tri-channel ram you should really have all 3 ram slots full for best performance. :)
ltcharles
yeah thanks i know i should but dual channel is doing just fine for now. I am working on the wc fisrt then i will add more ram.
Probably in 4 weeks i will.
Well I just ordered a 120mm slim rad to place on the top or rear not sure where but it has been ordered lol
