NathanP2007
- Dec 17, 2007
So I have put a SSD into my families living room Computer (Asus M2N Sli-Dexluxe Mobo) and installed Windows 10 on it. Everything is working perfectly (actually not true, having a weird problem with my Ethernet drivers but no fixes worked so I bought a Intel Gigabit CT PCI-E Network Adapter and that is working perfectly) but everything else is working perfectly. The SSD is acting exactly how I would expect it to.
However I noticed when I opened the Intel SSD Toolbox that I couldn't run the "Intel SSD Optimizer" and when I run the diagnostic scans it does scan it but it also says "The Intel SSD Toolbox cannot communicate with the selected Intel SSD."
Is there any reason to be concerned? Is this something I should fix ASAP or will using the PC for the next year as is be just fine (not being able to run the Optimized and such). Lastly, if I do want to fix it, how do I do that?
Thank you!
Thank you!
