my geforce fx 5900 256mb temps
Thats fine, its usually around that, right now my ambient is 41C and core temp is 51C, its been hella hot in Cali so its jumped up a bit. But yea, your fine.
Hi strangers. Can you tell me how to find out the temp of my GPU? Is it a third-party app?
What brand is it?, if its an Nvidia, it should be standard in your settings, Right click the desktop>Adujust display properties> Settings tab>Advanced>Nvidia tab, a side menu should pop up and then your looking for "Temperature settings"
my idle temp went up about 10C on my 5900 too. its been freakin hot here in cali.
hmmm.. Never knew nVidias had temp sensors.
Where abouts? I can't find any info regarding temperature on my card. Maybe it's an FX thing?
Yea, maybe its an FX only thing, you could try coolbits though and see if it can be unlocked? do a google search for coolbits, itll unlock any options in your det drivers that usually arent available
no, its only the very high end FX series cards that have em. I know that my uber low end 5200 doesnt have it:p
Recently installed that card back into my old PC; haven't bothered enabling Coolbits again. I did look before though, and there's nothing there about temperatures :(
