So, today, for the first time ever, I tried to solder something. Not to be deterred by any knowledge of what lay before me, I took a National LME49720HA and a Browndog TO99 adapter and I went at it. It was an enlightening experience to say the least.
The Browndog adapter may be ruined from my amateurish attempt, but at least, a fire has been lit...
So, should I also dip the tip of the iron in flux every once in a while? Are there any game-changing tips or tricks? And how was your first time soldering?
- The soldering iron was a cheap 25w RadioShack iron with the thin tip (like a thick lead pencil tip), the one that does not transfer enough thermal energy. If I put the solder and the iron on opposite sides and bring them together, the solder would just not melt. I had to put the solder and the iron maybe 30* away from each other instead of the ideal 180* angle.
- Because of this, the solder wouldn't create a pool and fill the hole. Only one time (for a reason that IDK still ), it went perfectly, and the solder job was so good that it looked like the back of my GTX 260 or my Creative X-Fi.
- But besides that, it isn't going to win any awards. It probably won't even work, because at least one pair of pins is bridged.
