Err... I think you meant to say inaudible, because no fan, even undervolted ones are silent.
Nothing is silent, anywhere in the universe. Absolute zero temps are required for that.
Glad we are extending the valuable discussion about my new AMD system.Nothing is silent, anywhere in the universe. Absolute zero temps are required for that.
Yes, this will get the full treatment soon. Proper loop for the whole thing. I might wait for the 7nm Threadripper, not sure yet.Looking good, though! Any plans to swap the AIO's out for a "proper" OL system, or are you quite happy with them?
Back in August I was doing in processing for a nuclear plant....they had an up and running Windows ME machine in the nurses office....
Had not occurred to me, but I can see where that might come to mind.On topic, anyone else getting H.R. Giger Xenomorph vibes from kyles finished build? The slick black tubes and hard plastic.
I can't help but think this would look really cool with a nixie tube fan controller:
I mean, it's a shitty controller (voltage control only, no pwm) but those tubes are damned sexy. I've debated picking one up solely for the RPM/temperature display, and not having it control anything.
Most likely will film it. When I do that I will put a RTX 2080 Ti in there with a block as well.Great system build and video documenting the process, Kyle. Glad to see, for the most part, the case swap is netting you a few benefits and Thermaltake is good with support.
Do you have any plans to film the liquid cooling implentation? I think it would be fun to see and educational for those wanting to get into liquid cooling but just need a little bit of guidance.
Fixed.I love the look of that build, very dystopian. Need to change your rig sig to reflect the changes...just a suggestion.
100% accidental. Just like black.There's definitely some "borg" vibe going on with that build.
The hinges on mine are steel, just checked. The doors stay closed so well, they are a PITA to get open. Bought mine at Microcenter at the end of December. Was on sale for $250, which was the top I was going to pay for a case as well.Interesting that you found the build quality on that case to be sufficient for your personal needs...I ordered one from Amazon and it came new, no damage to the box, but the crappy PLASTIC hinges that TT uses to hold the TG doors on was split about 60% of the way down...The door would still open and close but after seeing that and inspecting the rest of the case I found it very wanting and an u happy Amazon took it back.
I decided to give TT another shot since I needed a case that would support a 360(60mm thick) and a 420(45mm thick) rad setup for my sig system. I also wanted to keep it under $220 which excluded the very nice Enthoo line of cases.
I went with the TT View 71 TG edition, and while it is a massive case (over 75lbs filly loaded with the doors on) I still am only semi happy. The top glass panel was restricting the 3 120mm Gentle Typhoons that were exhaust on my top 360mm rad (even with the fans undervolted to 6.5V). Removing that glass plate dropped my load temps on all three Vegas by ~8C if I remember correctly.
I thought about doing the thicker one, but that would hide the mobo VRM heatsink fully behind the rad and I do not want to do that. Also, those XSPC rads do really well anyway, so I am interested in what it will allow me with PB Overdrive in a push/pull setup.I use that Silverstone fan hub in my Corsair Carbide 240. Works pretty nicely. Wishing I had a case big enough for a bigger radiator like that for the 2920. One day....
I have always just felt personally that these do a better job on radiators than Noctua fans. No knock on Noctua, they make great stuff, I have always had better results with these.How is the sound profile on these, and how would they compare to noctuas for case fans?
This is what AlphaCool had to say differing Z-height on VRAMs, which we know can be different: "The height is sometimes different. We are talking about 0,1, 0,2 up to 0,3 mm. And our manufacturing tolerance are around 0,1 mm. So, in some rare cases, if everything is going wrong, the different of the height could be up to 0,4 mm. That is the worst case scenario. And it seems like you got the worst case scenario."Looks to be about 2mm. That is a rediculous amount of difference for Z on a BGA package.
Don't think so.Perhaps part of the smoking gun?
That sure looks like more than .4mm! Be interesting to see how the thicker pads help.
Going with those nice shin etsu ones?
Yeah, GPUz will tell you what is on your card.Boy, nVidia really screwed the enthusiast market. I would be pissed it this happened to me. No way to even differentiate the RAM on the GPU box. Not at my PC right now, and I can't remember if GPU-Z tells you what vendor RAM is or not.
