Krispy Kritter
- Feb 13, 2003
So I finally convinced myself to make the jump to an IPS panel, and obviously spent extra to get a gaming model. I can't believe that I waited this long to try IPS.
The image quality is excellent, which I'm sure is partly due to the increased resolution. I did spend the time to calibrate the unit, and there are no defects that I've found yet. Although I will add that the front of the bezel is rather flimsy, not something I expected based on past Acer models that I've used.
And while I don't need two 27" 1440P panels, the quality difference between this and my old 24" 1080P TN panel is making me consider finding another 27" IPS panel to use as a secondary screen. Although the second screen wouldn't need to be a Gsync model.
I've only had it up and running 3 days so far, but I'm very happy.
