sladesurfer13
- Jul 6, 2016
Have this cooler for a while now. total of 9 fans and triple Radiator ( 240mm 45mm thickness Push/pull top mounted, 280mm 30mm thickness Pull front mounted and 140mm 30mm thickness push/pull Bottom mounted) Just reused old parts and turned it into portable external cooler. used an old handle strap that i got years ago. In Define Nano S itx case..Water Cooler and PC are hooked up to Wemo smart Plug. On/Off together via app on my smart phone
QuicDisconnect
