The SickleFlow (AKA the R4) is well regarded for its airflow to CFM ratio. I found one on sale and got it because of this.
But unfortunately, what I've noticed is that if I run it at any level below 8 volts, the bearing becomes audible. It constantly makes a ticking and vibrating sound. I have the fan sitting right next to me right now but I can even hear it inside my computer case. I tried putting the fan on top of a sponge, thinking that the fan's vibrations were going into my desk, but it still makes the rattling and ticking sound.
I thought of lubricating the bearing but since this is a "long-life sleeve" bearing, the cap is made of hard plastic, not soft rubber. I think it was not meant to be removed, so I let it go at that point.
If you have a Cooler Master R4, how do you like it? Does it make ticking or other sounds at low speeds?
