SixFootDuo
- Oct 5, 2004
9900K OC = all core overclock to 5.141GHz with 2x8GB 3600MHz memory. 8600K OC = 5.25GHz with 2x8GB 3600MHz memory. Both the 2700X and 2950X are both using Precision Boost 2. The 2700X is using 2x8GB 3600MHz memory and the 2950X is using 4x8GB of 3200MHz memory.Should be noted those 9900k overclock results are from a CPU speed @ 5.14ghz
highend watercooling, and thank you2213 is great for 'just' 5.0 ghz. This is more than some are getting with 5.1 ghz. Seems you have a kickass cooler setup.
A Ryzen 2700X OCed full tilt I believe tops between 1900-2000 points in CB (with well tuned DDR4)
So you can see the definite clockspeed advantage.
You can also run the single threaded benchmark too which I believe is under one of the settings you can change.
Nope... a 300 to 400 point gain over the 2700x is not an advantage at the 350 extra price tag. Considering how hard you have run that chip also.
2700x is a better CPU when all metrics are concerned.
Even in gaming a fully maxed out 9900k is only 11 percent faster on avg.
I see no advantage at all. It's like buying air jordans for 600 when a pair of Reebok can do the same for 60.
But congratulations on the fastest gaming chip. It is gonna make you super happy in sure.
Or a lambo when a corolla can get you from point A to B too. I'll take the lambo though if given a choice lol
Really and what metrics are those? Because taking gaming out of consideration, it is faster in other apps to and in some like premiere that can use its iGPU or photoshop which loves speed, the differences are big so dont let your passion for the red team cloud your judgementNope... a 300 to 400 point gain over the 2700x is not an advantage at the 350 extra price tag. Considering how hard you have run that chip also.
But unless you DO have a lambo, you've made the decision that it doesn't make financial sense to own one. That's the point he is making. That being said if you have the money the fuck it. I personally don't care what cpus people run.Or a lambo when a corolla can get you from point A to B too. I'll take the lambo though if given a choice lol
9900k at 5ghz with 4000mhz memory utterly destroys the 2700x rig in multiplayer games.
I honestly do not ever watch those single player gpu stress test benchmarks that review sites use to benchmark cpu's.
Another intel 8c/16t...
Huh??? At what 720p lmfao
it destroys it in 1440p by a massive amount that can only be seen and felt while playing games like bf1 and bf5 inside a full 64p server.
you can keep those static single player with nothing going on game benchmarks if they make you happy.
If you have some descent multi player benchmarks, many here would be interested.
Also, if what you say is true, than the 2700x would destroy her 8700k at 1440p as well.
Yep not enough benchmarks look at PUBG, Blackout etc for MP tests. I get they're highly variable but you can still run through the same area and get roughly the same gameplay everytime. In CoD they could easily do MP benchmarks but I don't see those either. I suspect the 2700x would lose, I think I remember seeing some early on where Intel had a decent lead. (edited post to remove hyperbole).
EDIT: Benchmark -
This is the 8700k vs 2700x and the 8700k is at stock. Now take a 9900k or 9700k cranked to 5 ghz, yeah it will obliterate the 2700x. The most important part of this video is when he's diving because it renders a big chunk of the map and Ryzen performance falls considerably behind. You simply don't find these kinds of tests in majority of sites who run canned tests. Even HardOCP fails in this regard because they don't test MP much if at all.
So you will get 350 fps in CS go vs 250 fps with the 2700x. You are also getting a few more fps while free falling in PUBG with no combat involved. Awesome.
Intel is where I'm always gonna spend my money first.
Oh please.. saint AMD is not curing world hunger either.. Its just another company trying to make money just like every other company out there.Even when they are illegal or immoral?
If you dislike Intel so much, why do you even bother hanging around the Intel forum? I don't waste my time with things I don't care about
EDIT: Benchmark -
I would hardly call that parity lolCPU performance debate these days is like comparing a Ferrari Enzo to a BMW M3, sure the M3 is a prestigious car and ranks in the A Cat sports cars, it is fast, tunable and sports car junkies dream, but it doesn't have the top end speed of a Ferrari enzo. On socio scientific basis the M3 is bought by more people and serves more usage than a Ferrari enzo.
The best test would be stock 2700 and a stock 9900K both with AMD and Intel stock fan solutions to represent cooling solutions out the box rated to 95w TPD, If the CPU fails to post a full bench the score is disqualified, but we already know the outcome of it, Intel won't post any scores because it will fail on stock cooling solutions. I guess since we are not really reviewing apples with apples we can then just rather do a bench with a 2700 running under phase change cooling ramped up to 5ghz then, that will create parity.
