ShadowOfJosh
- Dec 31, 2006
What all other resolutions will this monitor do besides 1920x1200? I would like to know, thanks.
anything less. Nothing more. Too many possible resolutions to name by hand as you can practically force any resolution smaller than 1920 x 1200.
Ok Thanks, I just wondered ... like some monitors show in specs resolutions it will do...
for example the lvm37w3 says it will do 1920 x 1080, 640 x 480, 800 x 600, 1024 x 768 on PC... http://www.westinghousedigital.com/details.aspx?itemnum=56#VALUE
So the BenQ would do 1920x1080 (16:9) over DVI on PC just fine maintaining aspect?
Thanks for your help sinbios! I don't know why I have been a moron for so long. I went out and bought a dvi to HDMI adapter for $13.00.Hi everyone, the pictures of video playing at different display modes (AR, 1:1, etc) really don't tell whether 1:1 mode is working correctly, or if AR is really 1:1 or if it's scaling the picture back and forth. Could somebody with a PS3 please display the above image and test each mode? If AR is truly working at 1:1, it should be a fine, smooth gray pattern. If it's scaled in any way it will turn into a very obvious checkerboard.
I have made these images in Photoshop to illustrate:
This is what it should look like, if it's 100% unscaled:
Scaling down and back up in Photoshop produces the following:
This will produce definitive results of whether any mode displays the pixels 1:1. If it works in 1:1 mode, but still has black bars on the sides, it may be that the original image is sized that way (i.e., not full 1080p!) to compensate for overscan.
Also, I'm still curious about the panel. Since AUO doesn't make a PVA panel, the BenQ guy is obviously talking out of his ass.
I don't think you can do 1080p over component, and I'm not sure how interlacing will affect the pattern... nice to see that it works fine in PC mode! Now we just need somebody to test over PS3 to figure out whether that's working correctly as well. I know I have a similar problem in my 720p TV, PC connections are 1:1 but other connections are scaled.Thanks for your help sinbios! I don't know why I have been a moron for so long. I went out and bought a dvi to HDMI adapter for $13.00.
Here are the 1080p test pictures that sinbios posted earlier over HDMI in 1:1 mode. It looks like you put that to rest, sinbios. It appears that 1080p works correctly over HDMI in 1 to 1 mode. There are about 1/2 inch bars on the top and bottom. It appears exactly the same in the aspect mode.
http://i171.photobucket.com/albums/u285/higgy57/006-2.jpg
http://i171.photobucket.com/albums/u285/higgy57/004.jpg
It also appears exactly the same way over the dvi input, which I think we already knew. Now if I can figure out a way to test it over component, I think I can.
Yeah, that's why I only use standard mode for regular usage. You might try that senseye stuff to see if that helps.I have a question for others using the 241XX Benq panel. I have the 241WZ.
Desktop text looks great using DVI input and standard mode, but if I switch to any of the other modes (photo, dynamic, movie) the text immediately gets blurry and I can't seem to change it. The sharpness settings also appear to be locked out on any settings other than standard. Is that what everyone else is seeing as well?
I've tried it, I didn't care for it because of the flickering. But this is the thing. No one that I know of has tried it on a true 1080P game. This will probably be a whole new experience. For me, the jury is still out.To everyone who got the WZ version of this monitor,
is the BFI function really worth it?
cheers.
Maybe the PS3 needs a firmware update.http://www.hardforum.com/showthread.php?t=1168778
This thread indicates that WZ ISN'T doing 1:1 over HDMI, but they're doing firmware updates...IOW, PS3 will have 4 black borders around it for now!!
I've been doing a lot of a reading about how to operate that screwdriver. That Chinese is hard to read though.And the next definitive test... involves a screwdriver! ;D
Oh, one more thing. There's a lot of banding on the colour shot, does that actually look like that, or is it because of the quality of the photo?
Yes there is a little banding in the green and a little in the red.
bcoz my e-tailer informed me they not gona get it untill 1st week next month. so i cancel my order.
cheers.
does any body knows the solution for the signal-lost issue? (blackout) problem
You got to be f....... kidding me? I just stumpled over this thread: http://www.hardforum.com/showthread.php?t=1168778
So, I just ordered this monitor, and know I find out that this monitor also have a problem? Can someone confirm that 1080p inputs are displayed incorrectly? With black bars all around the image?
EDIT: I missed the part saying it's on the HDMI input that there are problems. I will use my xbox 360 over component, so I'll keep my fingers crossed...
If you are referring to the FP241WZ as the monitor, then yes, there are some problems. On my XBox 360, I tried 1080p via VGA and Component video. It works in best in Component Video. Only if you used 1:1 mode, it would leave bars on the sides as well as the top and bottom. However, if you put the monitor in aspect mode, then it would be displayed correctly. I couldn't tell that it was doing any actually scaling, just displaying the signal as it should. It seems that BenQ is aware of this problem and may have a firmware fix in the future (according to the thread you mentioned). I personally don't care to ship mine in for a fix, as it does actually work correctly in a different mode than expected. Why bother if it works, just in a different mode, right? *grin* Anyway, I just did a comprehensive review of three 24" monitors, and they all have some irritations, or bugs, or whatever... Nothing is perfect, but we have to look past the irritations sometimes. *shrug* Later...
Does the 360 have a picture viewer? If so, could you run this test: http://www.hardforum.com/showpost.php?p=1030757347&postcount=210
This will show us whether 1:1 works correctly with consoles and component video.
I tried a different test pattern on my 360 last night. The xbox bounces it around or scales it in and out like a picture show. I wasn't able to just get a still image to display, so I can't verify 1:1, unfortunately. However, I did notice that on VGA, the monitor thinks the xbox is sending a 1680x1050 signal. My CRT also thought that it was receiving a 1680x1050 signal, even though I clearly selected 1920x1080. I think MS isn't outputting the signal entirely correctly.
Now, when the xbox is using component video, the monitor thinks it is actually receiving a 1080p signal, it just shrinks it down a little, and puts bars on the sides. I think that is the fault of the WZ. One of the PS3 dudes on another thread mentioned BenQ is going to update that for him (in Hong Kong). We might have a fix for some of this stuff, but it's hard to know if it is worth it.
MS needs to fix stuff... BenQ needs to fix stuff... I am sure Sony has to fix stuff, too. Heck, I think it's all broken!! Oh well, take the best you can get and just look past the flaws, or you'll never enjoy it. I guess I am ready to settle a little so I can have a big screen. Later!
http://i171.photobucket.com/albums/u285/higgy57/007.jpg
Edit: Please feel free to post your experiences, questions, ect. with the WZ model.
That is the first excessive ghosting compliant that I've heard of. It is strange that you didn't notice the excessive ghosting with the FP241W. I did notice a little ghosting on mine, but nothing serious. If it's not a defective cable, I would suggest returning it and trying a different monitor manufacturer.Well, just got mine today. But after reading some reviews and threads on this forum, I must say I'm a bit disappointed in this monitor.
First of all, the ghosting is insane. Much worse than I expected. Tested it in FEAR and Half-Life 2 so far, and the ghosting is clearly very visible. I've tried the PerfectMotion settings. This, as far as I can tell, eliminates the ghosting completely. BUT... The flickering of the screen gives me a headache. Just like playing on 60 Hz on a CRT screen used to give me. It's strange, since I didn't see it this clearly on the FP24W. Maybe it's just not calibrated good enough yet? Anyone have a good way to properly calibrate a LCD screen, please say so.
Second, the stand are somehow crocked. The screen itself tilt to the right and cannot be adjusted.
I don't know if it's a keeper yet. It depends if I can somehow so it up so that the ghosting isn't as visible as now.
No the banding isn't that bad. Sorry, I forgot to give you the original test image, http://aitoribarra.com/2006/12/01/1080p-test-image.aspxIs the banding as bad as it looks like in the picture?
I just got this monitor and my OSD-menue looks wierd. Can anyone take a pic of his/hers OSD-menue so I can see it mine is faulty.
Great, I was worried I lead you astray.Hello Higgy,
Sorry for the delay but I was away last week. They send me a RA number after 2 days and offering credit back. But I realized that the component of my DVD player were broken and not the monitor. So I kept the Monitor as I am very happy with it
