Why do you keep posting that the 240 is the best, its Not! The new RangeMax Next isOrinthical said:Just a friendly reminder... do a search before posting as this question gets asked quite a lot around here.
As requested:
The following is a compilation of the 'best' SOHO performance routers, as recommended by myself and others on this forum.
Best:
D-Link DGL-4300 -- $124.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833127158
Netgear WPNT834 RangeMax 240 -- $129.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833150023
LINKSYS WRT54GX4 -- $129.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833124052
Better
BELKIN F5D8230-4 -- $83.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833314014
NETGEAR WPN824 -- $99.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833150015
Good
BELKIN F5D9230-4 -- $49.99
http://www.newegg.com/Product/Product.asp?Item=N82E16833314017
Hope that helps.
-(Xyphox)- said:Why do you keep posting that the 240 is the best, its Not! The new RangeMax Next is
http://www.netgear.com/Products/Rou...axNEXTWirelessRoutersandGateways/WNR834M.aspx
no probumcpgrad said:thanks guys..
sorry about forgetting about the search button.. I always thought it was disabled..
