GOD'SlittleSERVANT
- Jul 18, 2001
I don't have the black edition, but is there a way to over clock this? Or should I even try? Is there a way to make games read two-four cores instead of the one?
so basically my games are running at 2.3 ghz? When will games start to support more cores? I feel this phenom was a waste of money.
Ahhh, I see I see. So there is nothing I need to do for that to happen, right? The quad core just kicks in when more shit is running?
You can overclock that, however overclocking a Phenom is like 50% voodoo. Even once you get the system to pass all stability tests with flying colors, they can randomly bomb out in Windows while running MSPaint
No way to make games use more cores, they need to support it.
Is that a myth or a fact?
I've seen both AMD and Intel systems bomb out while just idleing and be fine while loaded.
And I've seen it more on Intel stuff.
From what I have observed, it has more to do with the motherboard, RAM, and power supply than the CPU.
It can also seemingly cause by stuff being "out of sync"... messing with the different timings in the BIOS can affect the stability a lot when you are having freaky stuff happen like that. If you go back to the older systems, you can find guides about how to set stuff up to have the best throughput even if the timings aren't "as tight as they can be".
If it is stable under load, it should be stable at idle. If it isn't, there is something else wrong with the system.
The key is to change one setting at a time and then test.
Not necessarily. Some games (such as Supreme Commander) can take advantage of all four cores at the same time, but it's still pretty rare. However, some companies like Valve are throwing an enormous amount of R&D into games that can make full use of multiple cores and we should be seeing the fruits of this R&D in the next generation of titles. Take a look at this benchmark as an example of a quad core being used in full for a particle engine:
http://www.techreport.com/articles.x/14606/5
As for your purchase, I think that if you were really interested in gaming you would have been much better off with both a dual core processor and something made by Intel along the lines of an E8400. Your processor choice isn't terrible, but it's severely underpowered and although today's games tend to be much more GPU limited than CPU limited, this isn't going to hold for long and we're going to see games that are going to stress CPU power further and further.
And honestly, don't overclock a Phenom. It's just not worth it.
Thanks alot for your help. I really want to buy an intel CPU and mobo now, but I just spent money on this phenom
Cool, thanks. I just want the games I play to run off more cores. I'll check to see if any of my games I have do that.
