Intro Post 1.
Come here if you are interested in my journey into building a HTPC combined with a DAW based on an AMD 785G mobo..
Planning of Windows 7 x86 from HTPC running Virtual XP mode for the DAW. Let's see if it works. If not then I will re-install Vista x86 (Pro Tools 8 requirement).
Here is the list of components:
MEM 1Gx2|WINTEC 3AMD2800-2G2K-R R - Retail C$23.99
MB GIGABYTE|GA-MA785GM-US2H RT - Retail C$94.99
CPU AMD|ATH II X2 245 AM3 2.9G RT - Retail C$74.99
Reusing old WD 250 HD and WD 500 firewire external HD
Monitor Westy 1080p 47" - VM-47F140S
Case Antec Black Micro Fusion 350.
Here is the thread that talked about the choice of components.
