My 6800k died. What to do next?
Discussion in 'Intel Processors' started by lee0539, Aug 3, 2017.
  1. lee0539
    lee0539 [H]ard|Gawd
    1,804
    Nov 17, 2001
    So my 6800k died on me. I have to RMA it to intel. They will send me a new one. My question is what should I do with the CPU? Should i sell it and the asus x99 deluxe ii and go skylake x or should I just stick with the 6800k and save money or wait for 6850k or 6900k prices to plummet and buy that instead?
  2. BrainEater
    BrainEater Gawd
    951
    Jul 21, 2004
    If in doubt , Upgrade !
    :ROFLMAO:
    RedWagnum likes this.
  3. Archaea
    Archaea [H]ardForum Junkie
    9,786
    Oct 19, 2004
    X299 vs x99 doesn't seem like much of an upgrade. This vid compares 7820k vs 6900k vs 1700. The difference is......underwhelming.
  4. Nexus6
    Nexus6 Limp Gawd
    323
    Jul 29, 2004
    The only thing you'll notice upgrading to X299 is less money in your bank account.
    isp and techie81 like this.
  5. Skyblue
    Skyblue Limp Gawd
    264
    Jan 2, 2008
    Oth. what is a new 6800k with respect to a new mb and skylakex cpu. The ram is the same I suppose.
  6. Archaea
    9,786
    Oct 19, 2004
    Might consider one of the Xeon chips for your x99. You can buy them cheap on eBay. Especially the engineering samples.
  7. mnewxcv
    mnewxcv [H]ardness Supreme
    6,529
    Mar 4, 2007
    I guess I'll be the first to ask. What do you do with your computer? What applications do you run? Do you game? Do you use a lot of multithreaded programs?
    Nebulous likes this.
  8. Skyblue
    Skyblue Limp Gawd
    264
    Jan 2, 2008
    A better suggestion by far, if such xeons exist. I didnt think of that at all.
  9. arestavo
    arestavo [H]ard|Gawd
    1,435
    Mar 25, 2013
    ES Xeon chips aren't overclockable (maybe some QS samples can, but they are almost as expensive as the retail chips), yet the 16XXV3's can be multiplier overclocked (the V4s are now multiplier locked, so not real overclocking). I've actually got an 8C/16T 1660V3 up on the FS section.
    If you don't need to overclock and need lots of cores for cheap, then yes ES Xeons are a great deal.
  10. Gavian
    Gavian Limp Gawd
    407
    Jan 13, 2016
    You should sell me the 6800K for $150 and move on to Skylake my friend.
  11. lee0539
    lee0539 [H]ard|Gawd
    1,804
    Nov 17, 2001
    I mainly do lightroom and premiere pro stuff. Not really gaming much anymore
  12. Master_shake_
    Master_shake_ [H]ardForum Junkie
    10,459
    Apr 9, 2012
  13. mothman
    mothman [H]ardness Supreme
    5,216
    May 28, 2009
    I've heard of CPU's being killed but never dying. I too would like to know how. The 6800K is the last of the 'Soldered' 6 cores.
  14. lee0539
    lee0539 [H]ard|Gawd
    1,804
    Nov 17, 2001
    According to intel it was because I overclocked the ram to 3200 mhz. It just stopped working. Went to microcenter and they diagnosed it as dead cpu
