My 30mb/s home internet connection gets saturated when downloading speeds over 5mb/s…
Discussion in 'Networking & Security' started by Gatecrasher3000, Sep 29, 2017.
  1. Gatecrasher3000
    Gatecrasher3000 Limp Gawd
    295
    Mar 18, 2013
    So, I have a 30mb/s internet connection (confirmed with speedtest.net, and another site), but whenever Im downloading a file over 5mb/s (wired or wireless), on any system on my network, my internet gets completely saturated, and any other internet traffic comes to a grinding halt. My hardware is setup like this: Modem (Technicolor DPC3848V) > Wired/Wireless Router #1 (Asus RT-N66U) > Wired/Wireless Router #2 (Asus RT-N66U in AP mode), with about 3 wired devices, and 5 wireless, that are not all running at the same time. I usually use QbitTorrent to do large downloads, and I can see that that Im using 5-6mb/s, when I hit that point any other internet connection on my network is extremely slow.
    I know there a 1000 possible causes for this, but anything I should look at first?
    Thank you.
  2. boss6021
    boss6021 Limp Gawd
    344
    Oct 11, 2006
    Sounds like confusion between 5MB and Mb.
    Cmustang87 and admiralperpetual like this.
  3. Mackintire
    Mackintire 2[H]4U
    2,891
    Jun 28, 2004
    Plug directly into the router Asus RT-N66U with an ethernet cable and disable any wireless on your testing device
    Run this: https://speedof.me/ download a jpeg (top right corner icon on the web page) and upload the jpeg image as a reply here.
    Part 2: http://testmy.net/ click on Extras --> Combined Speed Test and upload the results here as well
    Pictures tell a 1000 words.
  4. faxel
    faxel [H]Lite
    101
    Oct 3, 2005
    5MB is about 50mb
  5. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,841
    Dec 23, 2001
    Thats your problem. You have way to many connections filling up your nat table or your are uploading near your max speeds. Try limiting your total number of allowed connections and or max upload speed in the BT client to about 80-85% of your max upload.
    admiralperpetual likes this.
  6. Biznatch
    Biznatch 2[H]4U
    2,224
    Nov 16, 2009
    What is your upload speed and how much outbound traffic is there when this happens? TCP traffic will get destroyed if you saturate the outbound line and it can't send ACK packets.
  7. rtangwai
    rtangwai [H]ard|Gawd
    1,369
    Jul 26, 2007
    Are you using stock firmware on the RT-N66U? If so flash it to DD-WRT, then set the IPtable from 4096 to 16,384 entries and timeout from 60min. to 90sec.
    It's not a bandwidth problem, it is an iptables overflow issue. I did the above to mine before I replaced it and my Internet connection never choked after that on a 50mb connection.
    Alternatively build a pfSense router - they don't use iptables at all. I built one for my gigabit Internet (that's why I retired the RT-66U) and it is 20% faster than the Bell router it comes with (using bridge mode to avoid doube-NAT).
