matrixfan0831
- Jul 30, 2004
To those who have painted there mouse and have kept the arrow buttons on the side. Did you sand then paint or jsut paint. And do the arrows come off when you sand?
File said:I painted my mouse with the same metalicast and same method as you did.
Do you expierence a build up of.. Gunk? Like near the thumb side underneath the back and forward buttons? Seems like residue from my fingers just gets into little.. build ups =\
Quit skimming, the posts already cover this questionmatrixfan0831 said:To those who have painted there mouse and have kept the arrow buttons on the side. Did you sand then paint or jsut paint. And do the arrows come off when you sand?
DRJ1014 said:the arrows are going to come off if you paint as well
UserError said:Yar, can't find any of the color I want. Anybody in the DC metro area seen any silver/green or red/blue mirage 2 tone paint?
Godo said:STRESSTEST:
How many coats of base/color/clear did you use?
How many times did you sand and with which grain?
Thanks
matrixfan0831 said:- dumb ques.
exaclty what kind of bondo
like the kind in a red squeezy thing like 4 oz or something else and do i need any other bondo stuff.
theshadow27 said:just wondering, ive tryed painting mice in the past, and it looks liek you did an awsome job, but how did you clear coat the paint? everything i use seems to come off with use... acrylic wears away, ive even tryed car wax, but its no good....
Godo said:Thanks for responding, STRESSTEST.
Two more questions for ya:
1. Will you sand the final color coat before applying clear coat?
2. Did you have any problems with the color can "spitting"?
The project is going great so far, but on the color phase I have had a lot of problems with the can "spitting" onto the keyboard (mouse got lucky, less area). It produces spots of deep color that are difficult to sand out. I've tried holding the can at different angles, but it always seems to do this. The excess builds up near the nozzle and starts running down the can... Any suggestions?
SimJoe said:yeah.. i was too lazy to take it off.. and i thought it might look good
lol, oh well
LOL, I hope you find some, if not I'd think some of the guys here would help out.Now the question is... Where to find duplicolor metalcast here in Thailand???
STRESSTEST said:no one here can legally ship it to you there unless they go by boat. Good luck.
