http://www.mushkin.com/epages/Mushk...a01e7274e273fc0a80102061e/Product/View/991153
Mushkin's newest PC3200 product. Lowest latency PC3200 found on the planet today. CAS2-2-2 hand selected 6ns chips screened for 400MHz CAS222 results! Tested 222 compatibility on chipsets including nForce2, Intel 865/875, VIA KT400.
Q: What is the difference between this new 222 build and the PC3200 222 - Black Hi Perf Level II?
A: The Black High Performance level II used the Winbond BH5 chips, which are no longer in production. This new 222 special build uses Winbond BH6. They perform just as well as the BH5 at 3200 speed, but may no be as overclockable in your system.
Q: Can I mix the Level II I have installed now with these new modules?
A: Yes. Compatibility is not an issue, they have been tested running together at 3200, CAS222.
