Mobo: A7N8X Deluxe (dual etherent connections)
Old (computer): ethernet card
Router: di-704
Modem: cable, toshiba pcx1100
Old is used as a file-server for this computer. How would I connect my cables so that one would be for ethernet and one for the local network? Would making the connection from my modem directly to one ethernet port instead of the router work?
The main reason is for speed, but if it helped the security of the file server that would be nice
I have no crossover cable and would like to do so without buying one.
These are the only two computers on the network.
Router: di-704
