Nickbaldwin86
- Nov 8, 2009
understandable and no worries.
the newest BIOS on Msi.com's download page is 23.2(which is 7681vN2) so if you are on that I would imagine you have throttling issues.
The beta BIOS is the only one that is working correctly and doesn't have throttling issues, refer to this post:
http://hardforum.com/showpost.php?p=1037847967&postcount=32
Also would like to note that I am using N35 beta BIOS, seems the same as the N34 beta BIOS
If you do plan to flash to this BIOS you need to read that thread and note that you need to use the "MSI forum flash tool" DO NOT use the stadard flash method
