MSI X99S GAMING 9 ACK w/ 4x MSI 1080Ti SEA HAWK PCIe channel assignments all messed up
Discussion in 'Intel MoBos' started by pclausen, Oct 12, 2017.
  1. pclausen
    pclausen Limp Gawd
    229
    Jan 30, 2008
    Hey guys,
    I have been fighting this for the last 5 hours and I finally had to throw in the towel and post here hoping for some suggestions.
    Here's the hardware:
    MSI X99S GAMING 9 ACK (latest BIOS installed)
    6850K CPU
    2 x G.SKILL Trident Z 3200-14-14-14
    4 x MSI 1080Ti Sea Hawk EK X
    1 x Samsung 950 PRO M.2 512GB
    Here's a pic of the rig:
    [​IMG]
    As you can see, there are only 4 cards installed in slots E1, E2, E4 and E5.
    However, a run down of what BIOS believes is installed in the slots shows the following:
    PCI_E1 running at x8:
    [​IMG]
    PCI_E2 running at x8:
    [​IMG]
    PCI_E3 running at x8: WFT, there is nothing in this slot!
    [​IMG]
    PCI_E4 running at x16: Why? This should be running at x8
    [​IMG]
    PCI_E5 running at x8:
    [​IMG]
    PCI settings as follows (believe, my have tried everything under the sun here, but nothing changes the above readings):
    [​IMG]
    Oh yeah, and the 950 PRO does not show up here: (nor did it show up in the board explorer pics above)
    [​IMG]
    But it does show up here:
    [​IMG]
    Integrated Peripherals settings are all left at default:
    [​IMG]
    Setting this made booting into the Win10 install already on the 950 not work:
    [​IMG]
    So, with WHQL support disabled, I'm able to boot into Windows, but within a few minutes, things get unstable and I'm not able to save anything to the 950 in the M.2 slot.
    Also, I'm completely unable to boot into Ubuntu from a USB stick. Stick works just fine in just about every other rig I have.
    So wtf is going on? Defective X99 mobo?
    Should I rip out 3 of the 1080Ti's? Really don't want to as everything has been leak tested at this point.
