I heard the 5960x overclock like a monster, I should get one and swap out the 6850k to see if it's much better. I was hoping to get the cpu to 4.6ghz, 4.4 isn't bad.
No it doesn't. 4.5GHz is generally the best you'll see and many don't go above 4.3GHz. I've got two that will do 4.5GHz. One that does it at 1.28v or so and another that needs 1.35v+.I heard the 5960x overclock like a monster, I should get one and swap out the 6850k to see if it's much better. I was hoping to get the cpu to 4.6ghz, 4.4 isn't bad.
I generally keep mine at 4.4GHz because that extra 100MHz costs a lot in terms of voltage and heat output. I don't think it's worth it but that's me.Thanks guys, Im happy with my CPU, i think i really need to put some volts thru it to get it above 4.4 but is 100 or 200 more MHZ worth it? Maybe only for benching. Ive settled on 4.4Ghz @ 1.21 volts. Was Prime stable overnight and temps are 55C to 60C max running Prime. When i game they dont get above 44C.
Yes! I'm having a lot of issues... I built this rig for streaming, and my webcam is choppy as hell, my USB audio interface cuts out and dies. There's a ton of DPC latency.Anyone experience of USB being flaky? Both of my 3.1 USB having issues if my keyboard and mouse are connected to it (orange USB port). Mouse would skip around like it's losing signal and keyboard would turn on and off. Also it would not recognize my DDR4 3000 Ripjaws V series. I could only use 2666 below or 3200 which is weird.
I don't know what this "good info" is that you're talking about, because I don't see anything useful.
But yeah I need a new BIOS and chipset drivers or something to solve this shit. I desperately hope it's not more complicated than that.
I'm using the same gear as my old PC which ran it fine - just way underpowered - so I'm extremely disappointed. It's driving me absolutely insane.
I thought I finally got it to a point where I could stream by setting the renderer in OBS to OpenGL instead of Direct3D 11, which seemed to bypass the major lag... but then I try to run REmake HD and it's stuttering again. Not even a heavy game... it's a fucking joke.
I don't know whether it's a graphics driver issue (of which I've tried multiple versions) or something with the motherboard/chipset/device drivers. All I know is that I want it to be fixed and just work so I can actually use it!!
Sorry to bump a older thread but i got this board about a week ago having a heck of a time getting a decent overclock best i have been able to do with my 6800k is 4.2 ghz with 1.30-1.33 volts stable in realbench and prime 95 avx my max temps are 60c in avx i did do 2 of the tweaks dan had in the review that helped me get 4.2ghz stable any help is welcome.
