MSI X570 Tomahawk review: possibly the best $200 X570
Pivo504
So there's one thing I really don't like about this bios. My cpu for sum reason keeps running on a load randomly. It never used to do this. Without anything running just browsing the internet it'll be on a load!?! Why does this bios do that?? If I'm just browsing the internet it should not put a load on the cpu.. Is there any other bios that didn't do this? Is it possible certain bios can make the cpu run hotter than others bc that seems to be the case!?
Nebulous
Are we on the same bios? This is not beta right?
Yes, it's the same bios. Nope, still a beta. Odd as on MSI's site it's labelled a Beta, but once installed it shows the 1.B0, so I don't understand that. And of course it's final so..
Nebulous
Have you tried the bios before this one? I don't have that problem.
Pivo504
No I haven't. I was actually on the bios that the motherboard came on dated 2020. This bios was the first one I ever flashed to. What suggestion?
Nebulous
CyberJunk
you can get a gigabyte Aorus Master X570S for around $259 now a days.
polonyc2
I'm using AGESA 1.2.0.3b (released in July 2021) with zero issues...I'm hesitant to update the BIOS since everything is working so good...I hear the newer BIOS versions fix issues related to Windows 11 (I'm still using W10)
ziggo0
Black Mesa Download Gawd
This has been stable for me ever since flashing. Spent several months doing per core PBO2 and getting my memory speed up to 3600 CL14, not really wanting to screw it up unless something has been fixed with the bios
Terje_P
The New beta bios would lag if I had my Chinese Bluedio T5 headphones plugged in, suppose it could just be the headphones as I usually dont have them plugged in, dont think I have had them plugged in with earlier versions. Strange as they should be in charge mode when plugged in.
