I've got an MSI RX 580 8 gb.. (the one with the black/white plastic cooling enclosure).
It worked about 2 weeks ago and then suddenly stopped working with some weird behavior.
I tested it in 3 different PCs/mobos.
When powering on it flickers for a second, and then everything shuts off again.
Then when pressing the power button again nothing happens.
To reset it i have to pull out the power cable from the PSU / flick the on/off switch and then it will do the same thing.
PC will power on and flicker for a second and everything shuts off. This basically happens in all 3 PCs i tested it in.
I think something must have shorted.
Any ideas for repair or what could be the issue?
I have a multimeter if anyone can give any ideas on troubleshooting.
Thanks!
Thanks!
