- Dec 19, 2005
"Normally we'd expect bigger gen-on-gen gains for the 8-core part than the 16-core part, but the 16-core 9000X3D pulling ahead by that much over its predecessor hints at the possibility of AMD either giving it significantly higher clock speeds, or the rumor about AMD deploying both 3D V-cache on both its CCDs could be true after all. The 9950X3D could end up roughly on-par with the 9800X3D if this turns out to be true, given that the gaming performance delta between the 7800X3D and 7950X3D is roughly that much—2-3 percentage points. Intel earlier this week officially announced the Core Ultra 2-series desktop processors. As part of the announcement, the company put out some first-party gaming performance numbers, which put the top Core Ultra 9 285K either on-par with the Core i9-14900K, or faster by 2-3%, which means it should land behind even the 7950X3D in gaming performance, and AMD is set to dominate Intel in gaming performance with the 9000X3D series."
Source: https://www.techpowerup.com/327613/...0x3d-amd-set-to-dominate-arrow-lake-in-gaming
