Bone_Enterprise
Enter in the Rear
- Apr 21, 2006
I am not a enthusiast, so I am going to buy one of these cards when I can.
So is this another non-reference card with a cooler design that is awful for SLI?
I don't understand why they put these bad coolers that spew heat out into the case on their best cards, the kind of people who buy these are the ones who want to SLI, and the reference blowers are better.
LMAO is this guy serious?You're not an enthusiast if you don't run multiple GPUs.
Even if you have a Titan X overclocked, it still cannot run every game on its maximum settings at 4K resolution and hold 60 FPS. You still need two GPUs for 4K 60 FPS.
If you're not gaming at 4K 60 FPS by now then you are not an enthusiast.
Also, multi-card setups are only a PITA if you go with AMD, because AMD's drivers are terrible. Nvidia supports SLI very well. The only 'AAA' game I've played in years that couldn't support SLI was Dead Rising 3.
144Hz 1440P displays are much more "enthusiast" than 4K 60Hz displays.
I've never heard of one person that went from a 144Hz display to a 4K display and not say the miss and prefer 144Hz over 4K.
As one of the world's leading brands in graphics cards, MSI is excited to introduce the new flagship of the MSI GAMING graphics cards lineup: the MSI GTX 980 Ti GAMING 6G.
Hello this is Newegg support.
Yes I would like to return my reference 980 Ti.
This item is covered by Newegg.com's Replacement Only Return Policy.
I have returned non-refundable stuff before.Too bad, so sad.
I will return it if I am truly not happy with it. I have never once even paid a restocking fee or return shipping as I have always had good luck with their customer service.Too bad, so sad.
Yeah they always take care of you in my experience.I have returned non-refundable stuff before.
Go into their web chat and complain, they'll take it back.
In my experience, non-reference coolers cool the graphics card (and ONLY the graphics card) better. Everything else in the case ends up running warmer due to the extra heat being dumped into the case.The non-reference cards cool better even in SLI than reference, assuming your system is set up appropriately to handle the added heat.
Counter-acting this effect by running case fans at higher RPM generally leads to generating as-much (or more) noise than the Nvidia reference blower. If you're ok with trading extra noise for additionally cooling, well... could have just run the blower faster, kept your case fans at low-RPM, and saved the rest of your components from the additional heat.
Looking pretty bad here with an oc.Kinda sad how over hyped the Titan blower has become over the years. So much misinformation.
Kinda sad how over hyped the Titan blower has become over the years. So much misinformation out there.
Only if you're willing to accept the trade-off of the rest of your components running warmer than they would if your graphics card had a blower cooler.Regarding noise, there is just no comparing the stock blower coolers at over 60% fan speed to additional case fan noise.
If you want to get your case/component temps back down to exactly where they were with a blower cooler, it takes a LOT of CFM and a LOT of noise. Even when it's not quite as loud as the blower cooler running at high-speed... it's still a lot of noise, and makes the cooler-swap mostly self-defeating.
Best solution I've found is using an NZXT G10 bracket to stick a Corsair H75 onto the GPU. Keeps the GPU cooler than stock AND blows all the hot air from the GPU out the back of the case. You'll need to under-volt the pump (7v) and use a better fan (Arctic F12 at low RPM) if you want it to be quieter than the Nvidia reference blower in all circumstances, though.
Unfortunately, yes. The pump on the Corsair H75 @ 12v is louder than the Nvidia reference blower at idle. If you want a solution that's quieter than the reference blower under all circumstances, you'll have to under-volt the pump.I'm getting H75 for my 980 Ti - was going to use my GT AP14 on the rad - is the pump noise that substantial that you need to undervolt it? I have a Kraken X60 on my CPU and cannot hear it.
I've have yet to find a case that can tolerate the extra thermal load of a dual-fan GPU cooler on a 250w card at noise levels that I would find acceptable.The point I am trying to make is that while yes, your internal case temps will go up with open-air GPUs in SLI compared to reference blowers, it will not go up enough to detrimentally impact your other components (again assuming you have adequate airflow in a properly-sized case).
I've been through the process way, WAY too many times:
Not happy with reference blower's noise at-load --> Swap to dual-fan cooler --> System gets overly-hot --> Turn up case fans --> Not happy with case-fan noise.
The ONLY thing thats been able to make things work cool AND quiet is AIO water (And that's modified AIO water, the stock configuration of something like an H75 generally isn't quiet enough either).
Our definitions of "working fine" are, apparently, wildly different. That would be FAR too loud for me to consider usable.I ran dual overclocked 560 Ti's with the Frozr II on them in an Define R3 for a while, worked fine.
Same day the new BTBAM album, Coma Ecliptic, comes out .MSI Gaming: http://www.overclockers.co.uk/showpr...odid=GX-287-MS
ETA: July 10th!
That's 4 fans dumping 340w of heat into the case... I couldn't even run a single 250w card with a dual-fan cooler an an R3 without it being overly-noisy. I can't fathom how you'd silence two 170w cards in an R3 without water cooling.
Honestly, the R3 tends to become a hot-box when a GPU that exhausts heat INTO the case is used (especially if you leave all the noise-canceling foam + fan-hole covers installed). It's really meant for water-cooling, where huge amounts of heat aren't dumped into the case.
Tried it, too loud in any configuration to be usable. I've opted to keep the factory blanking-plate installed (with noise canceling foam) on the side-panel.The R3 requires a side panel fan to bring in air and a back or top fan to push it out.
Not true. Even the front dust filter on my case, the one that has NO FAN mounted on it, collects plenty of dust. Air is very clearly coming through the front.The front panel fan slots are completely useless as the drive rack is blocking most air flow.
If you're somehow happy with the noise created by installing a side-panel fan on the R3, then our definition of "no problems with [...] noise" are, again, wildly different.I've used the same case with 2x ASUS 770 DCII and now 2x Gigabyte 970 Windforce coolers. No problems with temps or noise even though I have a 4.5 GHz 3570K and heavily overclocked GPUs.
Uh, the R3 is specifically plumbed for water cooling. Fits dual 140-mm radiators on top just fine...The case itself is kinda horrible for water cooling IMO, just hard to fit all watercooling components in it. Might be ok for AIO setups.
It didn't matter what, or how, I mounted a fan in that spot... it made the worst whirring noises I've ever heard.
Simple, because every day you wait is a day less the "investment" was worth because you know you are upgrading to Pascal when it's released alsoFull disclosure: Not sure why I'm so impatient since my 970's are working perfectly fine.
Ack...I am seriously considering the EVGA AIO 980Ti. My gut says just do it, but the wallet say don't you dare spend $750 for a graphics card
What video shows how loud the Hybrid 980Ti water pump is? I looked on google and I found none. I saw a review that said it was near silent and only hit 50c OC and at load.
First issue: my headphones are open, so the listening environment still needs to be quiet to avoid hearing outside-noise.Meh, i have all the fans at full tilt in my setup and i just slap on headphones. Total non issue.
Looked into the FT02. Interesting design, but SPCR gave it a fairly poor review. Cable management is a pain, and ALL of the included fans are total crap. Being able to "hear ticking over a meter away" from a closed, noise-insulated case is a bad sign...I bought the Silverstone FT02 when it first came out... 2009 I think. I had a Radeon 5870 reference blower in there for the first couple of years then switched to a Galaxy GTX 580 with triple fan blowing air in the case.
This Silverstone FT02 has been keeping everything cool and quiet for nearly 6 years and I think I have sprayed for dust in it once. Clean, cool, quiet. I imagine the FT05 would work well too.
Every single AIO I've tried sounds like an aquarium pump, honestly. The only way to fix it is to under-volt to 7v.I was thinking about getting the EVGA Hybrid 980ti, but then I saw a video on how damn loud the pump is... louder than my CPU Fan, 3 180mm case fans, and the psu fan. From what I have read anyways.
